Does anyone know where is the device key stored?
Originally posted by theodor View Post
Ok but how to revert to 20170825....
But please verify with Guest first if that is the right ones to flash in order to avoid Neflix-drm issue.
Magendanz has posted elsewhere that L1 can only be restored/installed using a special file from Videostrong based on the MAC code of the individual box.
Does that mean that whatever custom rom you flash you will loses L1 level, or is there a way to prevent ?
Expert may give better answer ...
EDIT : Wrong !
DO NOT " Erase All" or "Force Erase All"
see Magendanz CommentLast edited by P.X; 11 January 2018, 23:59.
No, you only lose it if you wipe/clear Keys (Overwrite) when burning with USB IMG file from comp (as far as I remember!!)
Just to update everyone on my Netflix issue that started suddenly. The seller has agreed to refund my purchase.
It has been deemed a hardware fault. I think it's related to the oemcrypto/trusted zone/trusted execution environment execution.
I can see these in logcat:
01-09 10:59:50.627 4101 4101 E oemcrypto_tz: [OEMCrypto_TEEInvoke:366] TEEC_InvokeCommand 33 ERROR! result 0xffff3024
01-09 10:59:50.627 4101 4101 E oemcrypto_tz: [_oecc33:1645] error return 28
Anyway, i am glad this is finally sorted and just got myself a Mi Box
Originally posted by Boleh View PostJust to update everyone on my Netflix issue that started suddenly. The seller has agreed to refund my purchase.
Originally posted by spaceship9876 View Post
you said that you flashed an ATV rom and changed your box to L3. Did you flash it with the official ATV rom or with this nexus 3rd party rom? Did you flash via micro sd or via pc. If via pc did you flash using default settings or did you choose "erase all" or "overwrite key"? I would like to try this nexus rom but don't want to change my box to L3.
Please let me know if you found a solution!
1- I gave the box a gift for a friend.
2- I ordered the new one.
It's hard to bring back your DRM without getting a DRM partition backup.
Mi box DRM backup example.
There are currently 2433 users online. 1 members and 2432 guests.
