I am aware that this thread is for the PLUS, but I just received my Rpi 5volt fan that I plan to install on my "L" box. The question for PX, in your opinion, is it worth installing. Even though, these S912 boxes run hot, it does not seem to affect the operation of it (or at least from what I see). I watched your video again to see how you did yours, and guess I will do something similar, except I will cut a square in the lid and place the fan on top of the lid.
As as my Plus having a heat problem, I haven't used it in quite some time, been using my "L" mostly.
Edit: I ordered this fan a short while after receiving my "L" box and freaked out when I saw how hot it was running. But since I have been using it for a long time, now, I don't see any heat caused issues.MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Originally posted by clarkss12 View PostI am aware that this thread is for the PLUS, but I just received my Rpi 5volt fan that I plan to install on my "L" box. The question for PX, in your opinion, is it worth installing. Even though, these S912 boxes run hot, it does not seem to affect the operation of it (or at least from what I see). I watched your video again to see how you did yours, and guess I will do something similar, except I will cut a square in the lid and place the fan on top of the lid.
I had a couple of random crashes running Kodi with out of the box OEM.
The Plus seems to get there a little slower than the L but still gets there ...
Seems according to Jancales the Magendanz FW self limits at 80C (but I prefer to run it cooler if poss.)
It has been very cool in the UK lately which helps with temps, but I think there will be more issues when room temp is more like 30C+ not 16C
The fan running at 3.3V is silent and keeps everything nice and cool even when playing 4K files.
I'm still exploring the passive options, but so far they are less effective (especially in summer) and cost more than the really cheap fan (I had the little switch already).
The fan does fit inside really easily and the few holes shouldn't be an issue (I guess)
PeteLast edited by P.X; 04 January 2018, 21:26.
PeteMK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Originally posted by Magendanz View PostThis device does claim Widevine Level 1 certification
Do you know which Widevine Provisioning Model https://storage.googleapis.com/wvdoc...ing_Models.pdf) is used by Mecool on M8S Pro+/L
Reason for asking is because since I've flashed ATV ROM onmy M8S Pro+, Netflix has started to give various types of errors and sometimes the box would reboot.
I have now reflashed the stock ROM (20171128). No more reboots but I continue to get Netflix errors.
I am thinking if I have somehow wiped the Widevine certificate/RSA keys on my box? Is that possible?
DRM Info is still showing Widevine Level 1, HDCP 1.xLast edited by Boleh; 05 January 2018, 03:44.
Here is my feedback flashing the stock firmware image 20171124 that is available in the Geekbuying blog.
I have 40x40x10 heat sink mounted with silicone paste.
Firmware performs the same actually as the OTA 20171128.
I have Nova launcher installed and removed the system apps Launcher and Vlauncher, to prevent booting in stock launcher. So far no stability issues.
In kodi I have audio passthrough disabled and debug logging enabled, with CPU temp constant displaying in screen.
Running a 1080p 5.1 sound movie in Kodi for 90 minutes temperature hovers around 70 - 72°C. My ambient temperature is 30°C
CPU-Kodi at ~68%, and that is how it runs on all S905X and S912 boxes since I started monitoring this in the past few months, which is pretty high.
I booted up a Beelink M18 and the very same movie, from the very same source. CPU-Kodi runs ~47%.
So that is the reason for the heat problems in Kodi, because running Mobdro or another TV app the box will run low 60°C.
Any one an idea how to lower the CPU-Kodi usage with these processors?
As a comparison, the Magendanz ATV rom runs about the same figures in temperature and cpu usage as the stock rom.
Hi!
I added a new feature (MMC Info) into the Amlogic tool v1.0.19.
I hope it makes it easy to identify the problematic boxes.
Please contact me if you have any useful info for development/fix.
ThanksLast edited by smrtprjcts; 05 January 2018, 10:13.
Good to have the eMMC check built in.
Never really tried to get auto frame rate to work but tried manual and my Amp rejected 24p mode
but ... Turned on Auto in your app and works a treat
Many thanks
Auto Frame Rate has also helped the Temp for my 4K test - 24P is less stress on the CPU it seems ...
was using default 60Hz
Thought this was getting a bit off topic, but rather interesting, so I have posted over in the main box thread
http://freaktab.com/forum/tv-player-...224#post699224
Originally posted by P.X View PostAuto Frame Rate has also helped the Temp for my 4K test - 24P is less stress on the CPU it seems ...
Originally posted by Jancales View Post
In previous posts you write you're running Kodi, but in the thread of the Amlogic app the developer makes clear that the auto frame rate only works on SPMC. Can you confirm it works on Kodi 17 as well?
There is also a fix for SPMC
EDIT:
You have to re-enable each re-boot and some files report wrong fps.
Change back to 60Hz is manual too after exiting Kodi.Last edited by P.X; 05 January 2018, 17:59.
There are currently 1658 users online. 0 members and 1658 guests.
