Originally posted by chmielu74 View Post
Hello Magendanz
Today I got MECOOL M8S PRO + the same eMMC. Can I flash TVStock Nexus ROM?
Thank you for your answer
Guest commented
12-13-2017, 16:05
Probably not. I'd try one of the newer OEM firmware releases first, just to see if that succeeds. If it ends up hanging shortly after boot, you'll need to revert to the M8S_PRO+-20170829.121614.V0321.img OEM firmware that was flashed in the factory using USB Burning Tool. Link: http://freaktab.org/3acc0ea053ee8feb
Or, at that point you've got a decent RMA claim and can ask for your money back.
I got MECOOL M8S PRO + with OEM firmware: 20170919.150557.V0619 and does not hanging after boot. My eMMC:
Toshiba
1652KAE
THGBMBG7D2KBAIL
VD5815 CHINA
Can I flash TVStock Nexus ROM?Last edited by chmielu74; 16 December 2017, 18:12.
Thanks a lot @Magendanz for your hard work!
You wrote today "Yes, you should be fine with the Toshiba eMMC."
Does this mean that it should work for
1/ all the Toshiba chips?
2/ the Toshiba chips <whatever> THGBMBG7D2KBAIL <whatever>?
3/ only the Toshiba chip with the following reference "1652KAE THGBMBG7D2KBAIL VD5815 CHINA"?
For instance mine is entering in the 2nd category and is coming from Taiwan: 16259AE THGBMBG7D2KBAIL KSY101 TAIWAN. Should I also be fine or should I avoid the flashing?
Thanks a lot and have a very nice week-end!
Hello Guest
Toshiba
1652KAE
THGBMBG7D2KBAIL
VD5815 CHINA
Guest commented
12-16-2017, 11:59
I have one more question
I have OEM firmware: 20170919.150557.V0619,
Can i flash firmware :"update_M8S_PRO+-V0619_TVStock-20171210" by local update with wipe data?
this is my first time.
"Magendanz commented 12-16-2017, 14:12
We've only found the problem happens with the Samsung eMMC 5.1 chipset (KLMAG1JENB - B041), batches SEC 652 to 713. No one has reported it with any Toshiba or Kingston eMMC chips."
Thanks for your fast answer! Hope I'm not the 1st one with this chip ;-)
I want to buy the mecool m8s pro plus from geekbuying:
Hong Kong-1 Stock | Buy MECOOL M8S PRO Plus YouTube 4K Netflix HD Streaming Android 7.1.1 Amlogic S905X 2GB/16GB WIFI 4Kx2K@60fps VP9 HDR10 online at unbeatable prices. ✓Free Shipping ✓Limited Time Sale ✓Local Warehouses.
Any idea if this version of the box will work with your rom? how to know?
Originally posted by Kroisos View PostFrom geekbuying they informed me that they updated the whole stock last week, so I guess it will be safe to buy it now..
Has anyone benchmarked running Kodi app within Guest ATV versus running LIBRELEC ? Do we really need to dual boot if we heavily use Kodi addons?
Hello Guest
Toshiba
1652KAE
THGBMBG7D2KBAIL
VD5815 CHINA
Originally posted by lezioul View Post
yep, but you need something more in order to play the content.
By default, chrome launch prime application (which is not working properly on this box)
Hi Guest , this sounds really exciting. I actually ordered a box with the W-chipset. Do you see any reason (apart from the bad EMMC batch) why your ROM should not work with that box? I will, however, only be able to try it out in x months time - x being the time it will take to proxess my order and ship the stuff to Germany ...USD 29.99 Free Shipping, Wholesale Price, MECOOL M8S PRO W 2GB/16GB Stalker MAG25X Android 7.1 Amlogic S905W KODI 17.3 TV BOX WIFI LAN HDTVLast edited by chessplayer; 17 December 2017, 23:56.
Hello guys. I hope really somebody can help.
I think, I shouldn´t have do a factory reset as I cannot enter TWRP and NAND mask mode anymore. I can still see NEXUS bootscreen.
I also tried SD-Card/USB-stick method, but nothing works...
There are currently 2752 users online. 2 members and 2750 guests.
