Originally posted by ready View PostHello,
I want to dump 20170829.121614.V0321 for Magendanz.
I run dump_partitions.bat from this tool: http://freaktab.org/35e8f91f3b91af60, but I go the error - see attached screen.
Could you please help me? Maybe there is another way to do it.
Hello,
I installed the Amlogic usb Burning driver but the software cannot find the device - please see attached screen.
What should I do to solve it? I want to dump 20170829.121614.V0321 for Magendanz.
#543.1Guest commented28 September 2017, 22:10Editing a commentI'm not familiar with that tool, and it may not be compatible with this device. Try this instead: http://freaktab.org/35e8f91f3b91af60
(It's pretty simple, but I've confirmed that it works on the M8S Pro+.)
Originally posted by mabocoglu View Post
Just be sure holding reset button pressed while you are plugging usb cable. If button is not pressed position, your computer does not recognise the device.
what is funny, that bricked box, the same... i can catch him and run usb burn program
Magendanz,
I just received mine with 20170829.121614.V0321 firmware, here's the link to the firmware duump https://mega.nz/#!ULI20bQK!BB_knxnfh...RgTFsl6qnpA6rI
Thank you! Here's a link to the burn package I created from this: http://freaktab.org/3acc0ea053ee8feb
Btw, if anyone can point me to how you pack it together as one img file to burn back to the box? I want to try burn back this to the box and see if it hangs.
It's actually not a simple thing to prepare the raw partition dumps. You've got to convert the system partition to a sparse image, trim the boot images (boot & recovery) by unpacking and then repacking with abootimg, unpack and repack the device tree blobs with dtbSplit and dtbTool, and then manually trim the bootloader in a hex editor. After you're done, you'll need the last burn package for the uboot binaries, then use Amlogic's Customization Tool to unpack Level1 and repack.
Originally posted by P.X View PostHi,
Hardware (component) change between my first and second boxes ...
BB-ROC170703PS - July Version : Chips marked ..
EMMC : SAMSUNG 646 . KLMAG2WEPD-B031 . S4ZN1010 (EOL 3bit MLC - Data Sheet)
Memory Chips (?) : C71V217400
BB-ROC170811PS - August Version : Chips marked ..
EMMC : SEC 701 . KLMAG1JENB . B041 . S558Z034 (Current 2bit MLC - Data Sheet)
Memory Chips (?) : D / G
Pete.
Samsung announces faster eMMC 5.1 flash memory chips
Hi. I have just received this box (M8S Pro+ 2g/16gb) from Banggood with a build 20170815.182813.v0321
I have read this forum, and couldnt see any reference to this particular build, and whether it is experiencing the same issues as the 20170829.
Has anyone successfully got TVStock running on this build, or should I be pulling it apart to have a look at the chips first?
Originally posted by Sossy View PostHi. I have just received this box from Banggood with a build 20170815.182813.v0321
Has anyone successfully got TVStock running on this model, or should I be pulling it apart to have a look at the chips first?
Are you able now to preapare the ATV for 20170829.121614.V0321?
I receive my order from.banggood. As this was my second box and the firmware 20170715. I just immediately flashed the atv rom. After about 30 mins playing around with the stock rom.
Anyway I had issues as the box was sluggish. And Netflix just kept on buffering..
I discovered embarrassingly late that I actually had a 1/8 gig device..
Based on what I experienced this was what other people were describing as a problem. But I would not know.if they also were using the atv rom..for the 1 gig ram model.
Would the nano rom.version be better for the 1 gb ram mecool?
Sent from my E6633 using Tapatalk
There are currently 1905 users online. 1 members and 1904 guests.
