Burning tool only shows connected with shortening pins...
VORKE Z6 Android 7.1.2 Amlogic S912 TV BOX 3/32GB eMMC5.0 WIFI BT Gig LAN
Not possible.. darn, that's unfortunate. I appreciate your challenge and frustration.
Did you follow the instructions from this earlier thread? It's for a Z6 Plus though.... :
(see post #4in this thread)
https://forum.freaktab.com/forum/tv-...te-20180126-sd
Hi guys, I was running ATVxperience (https://www.atvxperience.com/) on my Vorke Z6 Plus for a few weeks and then decided to try this ROM via SD card. I powered on the box with the reset button pressed and it looked like it was doing something but then stopped. BOOT was on the little LED display and VORKE came on the screen but then the TV said there was no HDMI signal. I powered off the box and removed the SD card but when I powered it back on I now getting nothing except the blue power button. The LED does not light up. What happened? The issue is viewable here... https://www.youtube.com/watch?v=iZtQ-x6FNJc
soldiaz I managed to get mine working again. I downloaded the atvxperience ROM and then the USB_Burning_Tool v2.05.15. When I connect my box to my computer and ran the burning tool with the atvxperience IMG it fixed my box. Hope it works for you also.
I then upgraded using the ROM in this thread again via SD Card and the same thing happened. Must be a flaw in the IMG file in this thread.
I think I was able to get mine working again because I must have interrupted the upgrade process the first time. This time after I fixed my box I let the upgrade via SD Card complete and my Box is dead again but this time my computer will not even detect it.
There are currently 2381 users online. 1 members and 2380 guests.
