VORKE Z6 Android 7.1.2 Amlogic S912 TV BOX 3/32GB eMMC5.0 WIFI BT Gig LAN
RASTAVIPER so your Tanix TX92 also get hot with Kodi playing, how much ºC?
and could you test this app, if the temp also go high, thanks
vliveapk.com ist die beste Quelle für alle Informationen die Sie suchen. Von allgemeinen Themen bis hin zu speziellen Sachverhalten, finden Sie auf vliveapk.com alles. Wir hoffen, dass Sie hier das Gesuchte finden!
i use movie hd (necessary v-player from google store) without any issues on my alfawise h96 pro+ with normal temperature.
here you have some more good players
http://everyday-tech.com/top-20-free...s-ios-android/Free Download YouTV german TV in your pocket v2.9.3 .Apk for Android Developed by YOUTV®, NETlantic GmbH. - Download YouTV german TV in your pocket Apk Latest Version
Originally posted by vliveapk
RASTAVIPER so your Tanix TX92 also get hot with Kodi playing, how much �C?
But yes, I was getting 65-70 degrees at Kodi
Sent from my ONEPLUS A3003 using Tapatalk
Originally posted by RASTAVIPER View PostMaybe you Should ask for the Tanix at the Tanix topic.
I recently got a T95Z plus to fix, that was running 92 degrees.
Originally posted by Jancales
65 - 70 degrees is not hot for a S912 soc,I think there are not many S912 boxes around that run cooler than that with Kodi, and also not harmful imo.
In general I don't think is good for any box to run at 90 degrees.
Originally posted by RASTAVIPER View PostWell, my living room has a normal ambient temperature.
This is my first post on Freaktab. I have a Vorke Z6 DDR4 (3gigs RAM, 32gigs storage). The current firmware I have installed is the official 20171221. I updated that using the Vorke's built-in OTA (update & backup option in settings). I now see on the Geekbuying Vorke Z6 page that there is newer firmware version 20180126 (however it's unfortunately not available in the OTA update feature). So presumably I'd have to install it via a micro-sd card or via a male-male USB cable to my computer. Sounds like a pain to install, and a risk of bricking it, so I'm leery of doing it. Bummer that Vorke just don't make this lastest firmware available automatically through their OTA update feature in the Z6.
Does anyone know what the differences are between firmware 20171221 and 20180126? (is it worth the effort to update?).
I also read in this discussion that the 20171221 firmware supposedly has a broken Mali driver. Is that confirmed for sure? I'm not exactly sure how it's broken?! And also apparently the 20171221 has an outdated OpenGL 3.0. Is there an easy update to the Mali and OpenGL driver issues? Any tips on this would be most appreciated. Thank you.
This is the VORKE-Z6-20180126-SD Change log:
1. Improve WIFI throughput, optimize network speed.
2. Repair blurred image when booting.
3. Unlock Vorke launcher (User Choice can be in the Set -> HOME options select android native launcher to start).
4. Add ROOT switch to Set (set to be restarted to take effect).
5. Add video playback frame rate adaptive switch to Set, off by default.
6. Update Chrome browser to solve the situation which the old version of some websites can not pop up the soft keyboard.
7. Add ariscreen apk, support airplay IOS 11 version, chromecast and so on. 8. Remove the speed test app and update the KODI software version to 17.6.
Thanks gatos814. Frustratingly, the 20171221 firmware has the same change log as the 20180126:
20171221 Change log:
My Vorke Z6 DDR4 has the 20171221 firmware and it does all the above, so it's a real head scratcher for me as to what the 20180126 would do differently....(if anything)
Originally posted by tillaz87 View Post
I already fixed it weeks ago, if you have twrp you can flash my fix https://www.dropbox.com/s/ofs27bj07h...1GLES.zip?dl=0
Anyone has a link for this 2018 z6 update? cant see anything on their website
There are currently 2186 users online. 1 members and 2185 guests.
