Tanix TX9 Pro TV Box Amlogic S912 Android 7.1 Dual WiFi, Gig Lan BT 4.1
    Click image for larger version  Name:	t2.png Views:	1 Size:	106.3 KB ID:	667889
    Main Features:
    ● It runs on the Android 7.1, which is stable to use. You can connect to a world of content and entertainment at home with the box
    ● Amlogic S912 Octa-core ARM Cortex-A53 64bit CPU. With high-performance CPU known for a fast speed
    ● Bluetooth 4.1 connectivity. Easy pairing with most Bluetooth-enabled devices
    ● Support dual band WiFi of 2.4G and 5.8G, with 1000M LAN port
    Gearbest
    great looking tv-box and great price as well 56.99$ with coupon code
    waiting for some benchmark tests
      Main Features:
      œ It runs on the Android 7.1, which is stable to use. You can connect to a world of content and entertainment at home with the box
      œ Amlogic S912 Octa-core ARM Cortex-A53 64bit CPU. With high-performance CPU known for a fast speed
      œ Bluetooth 4.1 connectivity. Easy pairing with most Bluetooth-enabled devices
      œ Support dual band WiFi of 2.4G and 5.8G, with 1000M LAN port
      Gearbest
      Wondering if you have any idea what the difference is between this and the tx92 box?
      The specs appear the same and I believe this is the newer of the 2 boxes.
      Any chance you are going to do some tests on this box?
      Cheers
        Could be, have to wait to see what arrives maybe week or two due to Holiday in China 4days
        Looking at pictures....
        PCB in turned over compared to the 92
        They add mentions Foresee eMMC TX92 has samsung
        Display different by the looks but does not mean much....
        Maybe someone will get one soon..
        And we know these adds can be a little crazy at time
          DDR3 or DDR4 ?
            hello,
            thinking to replace my Minix X8-H as there are some issues with playing ATMOS codes movies + some *.mkv movies are probably too heavy as is loosing sound for few seconds during playback.
            Havent been looking into Andorid TV boxes for some time (2y+). Seems like many new model on the market.
            Did quick look and found this one which i quite like by design and HW specs...Also M8S Pro - just need some with auto POWER ON (none POWER ON button)
            1. Do u have any other tips suggestions?
            2. Why is difference DDR3 vs DDR4?
            3. How is it with custom FW and Recovery now?
            Android devices: Minix X7 (gone) , Minix X8-H , MK808b Plus
            Video Out: Benq W1000+ 1080p Projector
            Audio Out: HDMI -> Yamaha RX-V467B + 5.1 Yamaha Speakers
            Remote: Rikomagic MK702 II, Minix NEO M1
            Storage: NAS Zyxel NSA325v2
              Today we can have a look at the Tanix TX9 Pro TV Box Amlogic S912 Android 7.1 Dual WiFi, Gig Lan BT 4.1
              Runs on the Android 7.1, 3/32GB Ram on this unit testing.
              Support dual band WiFi of 2.4G and 5.8G, and 1000M LAN port
              Lets have a look see
              The Box
              What's in the Box
              Display and Ports
              Remove base
              A few screws and the top AP6255 WiFi Chip and a LED Display for pretties on the top.
              Close up Of the Bits
              No Vents, Different Ram, emmC and WiFi as compared to the tx92 and TF card
              and a Fancy Light show on top..
              More to Come when I get it back together
              Thanks to Gearbest
                Well all back together, and nothing left over.
                Easy on and setup same setup as other Tanix TX92
                WiFi, Google etc setup easy no problems
                Apps installed again all good.
                No Problems see with temps, Max I saw was about 70c when Pushed..
                Rest 55~65c Idle now Down to 45c, don't think it will have any problems but a few Vents would have been nice.
                Remote does turn unit on from a power off state and is ok to use
                Let's have a look.
                Blue Glow of the Lid and a clock, maybe a little to bright.
                UI
                Ram and Storage Truth
                DRM Info
                CPU-Z
                Antutu, running 32bit A7
                Geekbench
                More Info >
                http://browser.geekbench.com/v4/cpu/4437839
                A1-SD looking Ok
                  Dear friend,
                  I would like to buy this box even though it does not have a Gear best memory card specifications. The box works with DDR3 or DDR4 memory??.
                  Please answer because I would like to buy this box just waiting for memory information.
                  Best Regards
                  • trebor
                    trebor commented
                    Editing a comment
                    Not sure about Ram, but in these boxes not much difference ddr3/ddr4
                    I think Card would be 32GB..most are
                  very low antutu score like for S912 box especially RAM score
                    Ok thank you for fast response Trebor .
                    Best regards
                    • trebor
                      trebor commented
                      Editing a comment
                      Heavy games you "may" see a slight improve with DDR4 over DDR3, but in general running I fail to see much if any.
                    Anyone figure out how to change the default launcher on this box? I would like to use Nova but it won't stick as the default even though settings says it is the default Home. I can't see anywhere in build.prop to edit out the current launcher which is Oranth Tanix.
ID:	681150 After a short use 80c.
                        Hi Trebor,
                        I found your thread and would like to put my 2 cents on it. If adding my review here is inappropriate, please remove the post. Thank you! :-)
                        There's a TWRP that works with this box. I used that one and it was working fine: https://www.dropbox.com/s/voz2fp7ye7...3_ViT.zip?dl=0
                        Please note that I read somewhere it is not recommended to be installed and I haven't done it.
                        TO get to TWRP:
                        1. copy the zip on a sd microcard
                        2. boot to original recovery by pressing the home button of the remote while powering the box on
                        3. browse to the external storage and run the .zip file
                        Here's a detailed video review of that box:
                        • trebor
                          trebor commented
                          Editing a comment
                          More the Merrier
                        Hello, loved this box since the launch, but Unfortunately I can't buy it now, currently have a m8s pro and would love to test the ui this box, please you could do a backup files of ux (launcher, settings, kill apps and Speedo test)? i'll be very happy to test this interface.
