Tanix TX9 Pro TV Box Amlogic S912 Android 7.1 Dual WiFi, Gig Lan BT 4.1
    As found not tested
    Glad to share the firmware for TANIX TX9 PRO TV Box
    SD Flash Firmware
    Recovery
    Update Param
    Flash guide, please refer to: http://blog.geekbuying.com/index.php...utorials-tool/
    Source:
      Originally posted by trebor View Post
      As found not tested
      SD Flash Firmware
      Recovery
      Update Param
      Source:
      http://blog.geekbuying.com/2018/01/t...date-20180104/
      Thanks, testing ...
      Looks much better then any release before this one
        Originally posted by Alianato View Post
        Thanks, testing ...
        Alianato Can you be more specific? I have these issues with previous version.
        Power supply humming in stand-by mode or box is shutdown.
        LAN speed drop to 10mbps when wakeup box from stand-by.
        Wi-fi is reconnecting. I only tried on 5GHz, channel 36.
        THX
          THX
          I have none of the problems you refer, in my case the box just hangs all the time, I am suspicious of an hw issue related with temperature, apparently the box does not hang after being disconnected for a while, but when I installed an app to measure temperature it only showed around 50º, which I found OK and contradicts the hypothesis of temperature issue, perhaps next test will be done inside the refrigerator.
          Last night when I was testing everything was fine but today I began to install a series of apps and it began to hang, google play is very unstable so I thought in installing opengapps, I will continue posting my results, one thing I can say for sure, I am very unhappy with this box
            as i said before, i'm thinking more of a power supply issue that causes the box to hang, than a specific HW issue on the box itself. the strange humming of the power adapter when box is off is not a normal thing....
            maybe some kind of power surge that makes the box hang up....
              I tried several power supply and that didn't change much, but most probably your power supply is faulty
                Well, after installing this update (20180104), Antutu 3D benchmark is failing- even won't start. Will try to revert to the December FW.
                BR
                Update: with December FW (20171222) Antutu 3D benchmark test is working fine.
                Last edited by rafiki; 11 January 2018, 23:14. Reason: Update after FW installation
                  читать тему
                    Anyone same issues with graphics colors on native decoding TV multicast streams (other HLS streams too but after longer time) ? tested on TX9pro-20171222.img
                    Sometimes after few minutes, sometimes after few hours... lower Hz extends time after you will see this: (every TV older or newer, it does't matter)
                      I just bought Tanix TX9 Pro and find it not good as advertised... It hangs from time to time, kicks out of Kodi, colors has been changed from time to time (see it on the picture: https://imgur.com/a/PiWRX )
                      It is very annoying while watching movie or anything else - it switch colors and nothing can be seen. Whatever I do with the box, picture on the screen can't be seen while colors are lost. After some time colors has been reverted to normal. How to solve this problem?
                      Thanks in advance.
                      Best regards
                      PS. Movie can't be watched https://imgur.com/57RFv1R
                      Randomly change colors, works like that for some time (tens of minutes), then normal colors come back for some time,... can't be more sorry for buying it...
                        Thanks in advance.
                        Best regards
                        Which bulid version?
                        It looks like an old TV hdmi colors so try to switch depth to RGB mode.
                          mXHX,
                          thanks for quick reply.
                          Build is 20170916
                          TV is Sony (HD ready, resolution 1080i), few years old.
                          In display settings, I can only turn off color deep, which I did. I will watch what is happening further.
                          Here is cought color change:
                            mXHX,
                            Build is 20170916
                            https://streamable.com/fsnjk
                            ..many google/youtube solutions are about this: try
                            Settings (or Droid settings) > Display > Screen resolution > Color space (or Deep color settings) > RGB 8 bit
                            ..it depends on version which you use so these are not exactly steps, but you will find it. Sometimes colors are inside Display mode resolutions.
                              Thanks in advance.
                              Best regards
                              I know the problem very well because I have a TV where that happens, apparently many Sony and Philips TVs manifest this problem, it´s related with color spaces.
                              I am not sure if stock firmware has this solved, but if it´s not or you change the TV :-) [most probably not] or you try to find a rom in this forum that works in this box and that have this solved.
                              I also have a Tanix TX9 Pro and if I knew all the problems it would give me, I would opt for another box, for instance the Beelink GT1 with Superceleron ROM is very stable and have this problem solved.
                              Tanix TX9 Pro is very very unstable, till the moment I can´t find a definitive reason, maybe is the power source, perhaps the box is not cooled enough, or the firmware is full of bugs.
                              I tried many things, spent many hours trying different roms and even diferent power sources, and I am more inclined for an hw problem, but as I said I am not sure.
                              Hope it helped
