Tanix TX9 Pro TV Box Amlogic S912 Android 7.1 Dual WiFi, Gig Lan BT 4.1
Originally posted by georgesat20 View Post
Does anyone can help me ?You may only view thumbnails in this gallery. This gallery has 1 photos.1 Photo
Hello georgesat20
I can see nothing Obvious to what may have gone...and as with electronics....the weakest link normally goes first
Maybe friend you have who is tech can track and trace.
Others may add to this but you need to know what you are doing to resolve. no a quick fix I am sorry to say
Learn from this mistake.
Never unplug power pack especially when 12 and 5v can be mixed.
I have killed one or two,
But have spare power pack remote and case and maybe some parts
Originally posted by kron574 View PostI have four tx9 boxes that i updated with the flash drive method two went smooth the second two after update they boot get to the Android logo then go to a black screen sitting there?
Both can be downloaded from the Tanix site.
Kabelventje No go I have two that bricked i think. I can't access recovery on either both have no Boot logo on the front and both don't display nothing . The first one when i try and flash with burning tool it fails around 2% with a 0x10105002 error. Second one with same Usb same and same firmware Feb2018 it flashes fine but says boot with no image now, but when i plug in a hdmi cord it doesn't show boot at all? This all started when they arrived they were freezing a lot tried doing a factory reset that didn't help then i went and flashed the new Feb firmware and now im bricked
Alianato which firmware link is dead i got the same error on one of my boxes like georgesat20 I know it's not my usb or the way im flashing becaues i have flashed several other boxes fine prior.
Originally posted by kron574 View PostAlianato which firmware link is dead i got the same error on one of my boxes like georgesat20 I know it's not my usb or the way im flashing becaues i have flashed several other boxes fine prior.
http://freaktab.com/forum/tv-player-...ms-android-7-1
http://freaktab.com/forum/tv-player-...7-std-ultimate
I have not managed to play smooth 24p content with this box and kodi 17.6. Even if I set the resolution in the tanix at 1080p 24hz when I play a movie at 24fps the playback is choppy. This is happening only on Kodi and not in narive android player. Any suggestions? I have already try all possible settings via Kodi such as adjust refresh rate to screen etc with no success.
Originally posted by drakman View PostI have not managed to play smooth 24p content with this box and kodi 17.6. Even if I set the resolution in the tanix at 1080p 24hz when I play a movie at 24fps the playback is choppy. This is happening only on Kodi and not in native android player. Any suggestions? I have already try all possible settings via Kodi such as adjust refresh rate to screen etc with no success.
https://forum.kodi.tv/showthread.php...420#pid2782420
Basically you need to set Android system resolution of 50Hz and reboot and also use SPMC 16.7.04 with the Sync Playback to Display option enabled. (Settings > Videos > Playback)
Your TV must have a 50Hz mode in Android settings > Display > Screen Resolution.
You will lose all audio passthrough, but video playback will be nice and smooth on TV's that also have a little bit of motion smoothing enabled.
There are currently 1828 users online. 2 members and 1826 guests.
