Thanks in advance!
NEOMODE CUSTOM ROM 1.3 - MK802IV, UG007B, CX-919, MK809III with AP6210
help me please for reinstall neomode rom
hi ...... NeoMode I write from Italy ...... I have to be a hopeless case, I read around that a lot of people satisfied with the 802 mk iv, they say just update the latest official firmware and move the antenna, which I did myself even though I was perhaps the ' only thing that worked steadily the same, then ...... pretty much the custom rom NeoMode worked great, until last night ..... then it started to give me problems loading internet ..... I rebooted .... fixed screen without starting ...... reboot (of course ex-feeding) screen rikomagik fast as ever, with the circle NeoMode fixed screen without loading another (obviously waiting for a few minutes, after several restarts, I try to reinstall the rom NeoMode .... ok ..... usual problem ..... then step tool to batch officer rikomagik and reinstall the updated firmware (the factory do not have one) trying with the restore button which should serve their x the factory firmware, in short, after several attempts, it restarts (with firmware ap6210_2013905_1080p) old problems, not too reactive system and the internet that charge very badly, retrying with NeoMode number of errors at the end of check (idb on rkandroid erase tool can always be done before updating the rom?) during these attempts, the last I happen ....... "Windows Explorer has stopped working" and now no longer recognizing the mini pc ... even restarting or updating the drivers, then that is solved ..... while connect to pc, reset button, usb otg cable outlet, and also after dc power jack on ..... split ..... but now I still have the problem that I can not load the rom "NeoMode", as I said before, the official rikomagik not internet or be very slow .....
so now the problem would be "reduced" to the fact that I would be fine with just the internet rom NeoMode, I was fine with 720p, I tried in every way to reinstall your rom, before doing the erase idb, after you have loaded all the "system" do you make check and make only 4 kb and tells me "run fail error download failed" ..... because you can choose with the ticks to charge what you want even in part I tried to load only the "system", and "run ok" ...... but lacking everything else obviously wrong, and if you upload the rest after I start over again excluding precisely the system.
as I told you with the official firmware updated travels well but does not go, and does the little signal x, by the way I made the change to move the antenna, that is, on the internet there is, good or bad pages the opens (when he wants), but for example on the store hardly can not download an app, how to go on youtube, for me is a mystery ...... hello
Since this ROM doesn't have Live Wallpaper you can add it back. Install Root Browser from Google Play. You'll need to find LiveWallpapersPicker.apk and install it. I found it in the System\app folder in the Finless Rom. I used a thumb drive to transfer the files.Tronsmart R28 PRO with wasser-2.0.7-beelink-r89-rk3288 ROM and MX Player
Originally posted by babnik80 View Posthi,
i installed the 1080p version, and i can not download the real racing 3(not supported by device).
any tips on how i can do it?
thanks neomode, everything else works great on me!Tronsmart R28 PRO with wasser-2.0.7-beelink-r89-rk3288 ROM and MX Player
Originally posted by neomode View PostHello all,
Here is the Update Version of my Custom Rom for the follow Devices, this release is only for the Stick´s after 07/2013 with the new WI-Fi Chip AP6210.
I updated the Rom with a New System and the Kernels from sam321 for 720p and 1080p.
*Thank you sam321 !*
I have not included the OC Kernels, if you want OC Kernels go to here.
The Rom is Rooted and comes with the Stock Launcher and my Android TV Launcher.
Tweaked the Rom for Speed and Stability, follow Apps I have included.
- Ultra Explorer (Open Source File Manager)
- Opera Web Browser
- Chrome Browser
- Freaktab Reboot App
- BlackScreen App
- YouTube
- Xposed Installer if Netflix not Work
I have Test the Hardware as follows:
Bluetooth Works, tested with the follow Hardware:
Bluetooth Mouse, Bluetooth Keyboard, Bluetooth Earpiece
Camera Support I Tested with a Logitech C225 on OTG Port with Skype and work.
Downloads here:
720p Rom Download:
1080p Rom Download:
Regards Neomode
-AaronTronsmart R28 PRO with wasser-2.0.7-beelink-r89-rk3288 ROM and MX Player
Originally posted by poppillo View PostHi Neomode!
Yesterday I restarted the mk802iv in order to make a clean test.
I plugged the official power supply; I used the OTG port for my keyboard/mouse and I used the standard usb port to connect the network adapters.
So...incredible! All the network adapters and the webcam works out of the box !!!
I tested twice.
Maybe problem was related to my powered usb hub that powered also the stick via the OTG port
So I'm happyto tell you full compatibility for:
WEBCAM:
-Logitech c310
NETWORK ADAPTER:
-BELKIN Gigabit USB 2.0 Network Adapter (P10812-F5D5055)
-Official Nintendo LAN Adapter Wii
Thanks for your support!Tronsmart R28 PRO with wasser-2.0.7-beelink-r89-rk3288 ROM and MX Player
Originally posted by serfedo View PostDear neomode, all
should this crom support CX-919II stick with AP6210 which produced before 7/2013 ?
I couldn't enable WiFi after burning image 720p.
I'm afraid due my stick produced before 7/2013 - it is not supported ?
I have the following text at PCB:
2013-06-17
CYXTECH_RK3188 909
V1_1
[ATTACH=CONFIG]3564[/ATTACH]
Kindly help with any advice or link for right CROM for my CX-919II..
The exterior is looks the same as all others CX-919II or J22
e.g. http://pic.pandawill.com/media/catal...k/sku41917.jpg
br
Serfedo
Hi, did you manage to sort yours out, as you have the same board as mine, and i am having problems enabling wifi
There are currently 1514 users online. 1 members and 1513 guests.
