Again Thanks for keeping supporting the CX-919!!!
NEOMODE CUSTOM ROM 1.3 - MK802IV, UG007B, CX-919, MK809III with AP6210
For me 1080p kernels are a NO GO... Even the overclocked kernels (1.8Ghz, 1400Mhz, 800Mhz) stutter running 1080p videos. And I have the "HDMI flicker" problem (the signal goes down for about 3 seconds and comes back on) that happens at completely random times. I have a fan cooling the device so it is at a normal temperature and it never restarted.
Running dmesg shows me a lot of the "insufficient priv bla bla bla..." errors.
My last hope is that using the 720p kernel (no OC) fixes the "HDMI flicker".
I really need a miracle on my device...
Also can someone explain to me the difference between having 720p kernel running at 1080p and a 1080p kernel running at 1080p?
CR9 - Cloudnetgo AP6210
Originally posted by Skyback View PostFor me 1080p kernels are a NO GO... Even the overclocked kernels (1.8Ghz, 1400Mhz, 800Mhz) stutter running 1080p videos. And I have the "HDMI flicker" problem (the signal goes down for about 3 seconds and comes back on) that happens at completely random times. I have a fan cooling the device so it is at a normal temperature and it never restarted.
Originally posted by neomode View PostHave you both try a different PSU ?
May this will help. Because the lost of HDMI Signal says to me something not ok with the PSU.
Ray
EDIT:
I'm looking at this one: http://www.****.co.uk/itm/1410419875...84.m1438.l2649
But I don't know if it's good or not... :sLast edited by Skyback; 08 October 2013, 22:09.
Streaming 1080 over LAN
Hi
I have UG007B not rooted, 2G/16G. Streaming 1080 video over lan is very choppy with the stock rom. Streaming local file is OK (not perfect). Antutu test is 17500. Quadrant test put this device on the top!!!
Does your new rom fix this problem ? I use MX player with HW+ decoder. Wifi is very fast (65M), no issue with BT. My video format is M2TS from Sony camera. Thanks.
almost good
"Hello Neo, Nice work you done with the 1080. The only problem I had is when I switch the cable from computer to power source next time that I have to boot the rom goes looping and never starts.The other version before that was working fine but 720 only"
Originally posted by neomode View PostHello all,
Here is the Update Version of my Custom Rom for the follow Devices, this release is only for the Stick´s after 07/2013 with the new WI-Fi Chip AP6210.
I updated the Rom with a New System and the Kernels from sam321 for 720p and 1080p.
*Thank you sam321 !*
I have not included the OC Kernels, if you want OC Kernels go to here.
The Rom is Rooted and comes with the Stock Launcher and my Android TV Launcher.
Tweaked the Rom for Speed and Stability, follow Apps I have included.
- Ultra Explorer (Open Source File Manager)
- Opera Web Browser
- Chrome Browser
- Freaktab Reboot App
- BlackScreen App
- YouTube
- Xposed Installer if Netflix not Work
I have Test the Hardware as follows:
Bluetooth Works, tested with the follow Hardware:
Bluetooth Mouse, Bluetooth Keyboard, Bluetooth Earpiece
Camera Support I Tested with a Logitech C225 on OTG Port with Skype and work.
Downloads here:
720p Rom Download:
1080p Rom Download:
Regards Neomode
Originally posted by mccpiloto View Post"Hello Neo, Nice work you done with the 1080. The only problem I had is when I switch the cable from computer to power source next time that I have to boot the rom goes looping and never starts.The other version before that was working fine but 720 only"
- Opera Web Browser
- Chrome Browser
- BlackScreen App
- YouTube
Downloads here:
720p Rom Download:
1080p Rom Download:
Regards Neomode
thanks a lot for You ROM !
It works OK on my MK809III new WIFI !
Just now I est my just arrived ' USB 2 ETHERNET CONVERTER '
It's NOT OK
Specifications:
DIGITUS
.Ethernet IEEE 802.3 10BasseT and SB2 compliant
. 1xRJ-45 (STP)
. Support TCP/IP, NetBEUI,IPX/SPX
I install it in windows 8 ... just install drivers and OK
Any chance to be OK on my MK809III working great thanks to Your Rom ?
Thanks in advance
Originally posted by neomode View PostHello,
To help you I need more Information.
What's a Type of USB2LAN Adapter it is ?
This means Name and Type Number.
Need this to find the right Driver for the Chip inside.
Neomode
I appreciate It a lot
I read this on the BOX: DIGITUS DN-3016-A VPR 1.1
and I found this link
Welcome to the home page of the DIGITUS brand - One of the leading suppliers of computer accessories and network technology. You will find all infos here.
Hope it's OK for Your investigation
Best regards
many thanx, i used your rom on my Jesurun MK 809III. it works like a motherf%*% i tried serveral roms, but this was the onlyone that got the streaming video right on several apps like RTLxl (dutch channels) (all the others freezed). there are some questions on this rom though.
- why is the speedtest.net not supported in this rom?
- is there a way to find a workaround on the not supported videofiles. With some apps like 3fm radio app the video stream is not supported. i dod not try any on my server yet.
again, many thnx for the good work...
Neomode
on http://forum.xda-developers.com/show....php?t=1274656
can help in a way ?
I'd like to try ....
How to put in recovery mode NEOMODE ?
I try by using 'reboot recovery' via 'reboot.apk' available in NEOMODE but NEOMODE reboot normal.
There are currently 3060 users online. 0 members and 3060 guests.
