Gesendet von meinem GT-I9305 mit Tapatalk-4 now Free
NEOMODE CUSTOM ROM 1.3 - MK802IV, UG007B, CX-919, MK809III with AP6210
I have this idea that arouses my mind:
I could mount (via adb) the system files in R/W and then install the unzip and the drivers via adb :
I'm speaking still about:
[DRIVER PACK] USB to Ethernet driver pack for Honeycomb 3.2
on http://forum.xda-developers.com/show....php?t=1274656
What do you think ... it's worth it to try?
Best regars
CX-919II dual-antennas 2013-06-17 on PCB
Originally posted by neomode View PostHello all,
Here is the Update Version of my Custom Rom for the follow Devices, this release is only for the Stick´s after 07/2013 with the new WI-Fi Chip AP6210.
should this crom support CX-919II stick with AP6210 which produced before 7/2013 ?
I couldn't enable WiFi after burning image 720p.
I'm afraid due my stick produced before 7/2013 - it is not supported ?
I have the following text at PCB:
2013-06-17
CYXTECH_RK3188 909
V1_1
Kindly help with any advice or link for right CROM for my CX-919II..
The exterior is looks the same as all others CX-919II or J22
e.g. http://pic.pandawill.com/media/catal...k/sku41917.jpg
br
Serfedo
Hello, I can't get Netflix working properly with this ROM. I tried running the Xposed framework and Netflix module, but the Xposed Installer merely reports "Cannot read /data/xposed/modules.whitelist. The Xposed framework is not installed." I also tried installing the most recent Xposed APK and have the same issues.
Does anyone have any advice? I have a Tronsmart CX919 purchased recently. Thanks
UBUNTU - LINUX for this family: "MK802IV, UG007B, CX-919, MK809III with AP6210"
Hello Dear NeoMode,
you know I'm playing with my MK809III (AP6210) ....
I also tried NeoMode 1.7 but for my box is more stable 1.3
I tried to install Ubuntu on SD, as described in a lot of forum, but my box never boots using the SD card and therefore Ubuntu don't boot
May I ask You:
Ubuntu in this 'family box' is a topic that you are passionate about?
May be You can define in Your boot to check first if the SD card has a bootale OS ... ??!!
I'd like to inform You that my box is ready, if You need, to these things
Up to now the most interesting tentative in Linux ( NOT USING SD CARD) has been:
"Exciting new proper dual kernel (Android and Linux) multiboot capability "
by: Jan Morrison
link:https://plus.google.com/app/basic/st...xhmmbjbty5sk0k
but on my box when I select Linux i got the error:
... no bootable linux available ....
Bye for nowLast edited by write-tome; 20 October 2013, 12:56.
Originally posted by babnik80 View Posthi,
i installed the 1080p version, and i can not download the real racing 3(not supported by device).
any tips on how i can do it?
thanks neomode, everything else works great on me!Last edited by capache; 22 October 2013, 22:21.
Originally posted by neomode View PostUse the a App from play store called build. PROP EDITOR AND MAKE YOUR CHANGES WITH IT this will work.
Neomode
Which values I have to change to get all apps compatible as if I had a Nexus 7?
should I change all ro.product.*?
Thanks in adavance
Great !!!
Just wanted to step in and say (after I am back now on an original MK802IV):
Great rom, runs perfectly for me. Solved all my stutter issues.
Wifi is also very nice, giving me 2MB/sec transfer rate over ftp.
Now I am finally a very happy user !!!
The only remaining question is for me: It seems I cannot get into recovery mode at all. It always boots the rom again.
Is there any way? Ideally I would like to have clockworkmod recovery installed, but could not find it anywhere (although sure I just missed it) - maybe someone could kindly help me on that one? Thanks!
Thanks for sharing this rom with us
AndiLast edited by andip71; 23 October 2013, 17:26.
There are currently 1409 users online. 3 members and 1406 guests.
