Neomode
NEOMODE CUSTOM ROM 1.3 - MK802IV, UG007B, CX-919, MK809III with AP6210
Originally posted by neomode View PostSorry but I can not regonized any video jitter, as you may know I use the custom kernel from sam321 this kernel had the fix inside for this failure.
Neomode
slight problem maybe me being a newb cant get my pc to see my mk809iii turned on usb debuging turned on connect to pc plugged dc into the pc not sure whats wrong? its my first time flashing these android sticks.
AW: NEOMODE CUSTOM ROM 1.3 - MK802IV, UG007B, CX-919, MK809III (must Confirmed) with AP6210
Hello Cruz.
To flash your device you must set it in flash mode.
I have linked above a how to four this.
In short, you have a reset button on your device press and hold it than connect your micro usb cable to the device.
Until windows regonized a new hardware.
Than release the button.
Then you must install the driver from my package. After this you can flash the Rom.
Neomode
Neomode
CX 919
Tested all available roms on my Cx-919 but this one is the only stable rom available till date.. I confirm that it is working fast and stable on Cx-919. Bluetooth and Wifi is super fast and boot time has amazingly reduced. Webcam (microsoft HD5000)and skype test is positive. Great work guys
I think the problem is the in the kernel.
As you may know we have make a custom kernel for it. I think the modules for the lan adapter nor in the kernel.
I will see to get the modules.
Neomode
If you will find the modules, could you please tell me if you are plan to put it into a new version of your rom / kernel?
like... ROM 1.3.1
or
I'll have to do some manipulation via the terminal in order to load them?
Thanks again for your work!
AW: NEOMODE CUSTOM ROM 1.3 - MK802IV, UG007B, CX-919, MK809III with AP6210
First to the old mk802 iv. There will be a new version I'm working on it. Please let us not mix up the threads for the old and new mk802 IV.
Next.
For dmesg do the follows.
Use my Rom then install terminal emulator from playstore.
Open it and type in the follow.
su
dmesg > /sdcard/dmesgnameoflanadapter. Txt
This do please after plug in the lan adapter. After this post it here.
Last
What do you want to Test ?
Neomode
Originally posted by neomode View PostFirst to the old mk802 iv. There will be a new version I'm working on it. Please let us not mix up the threads for the old and new mk802 IV.
Next.
su
Last
Neomode
i have an mk809iii and i am having problems to create my gameloft fix because i dont have twframework-res.apk to create mine, how can i do it?
and, i can be a tester, i can test all you would like to make this rom faster... i am anxious, really needing it hehehe
Originally posted by neomode View PostDid you have the old or the new one ?
Neomode
so i changed to a neomode but it dont have a the fix. how can i get this fix ?
i found it on google
http://www.slatedroid.com/topic/5035...check-or-loop/
but i dont have needed twframework-res.apk
how to get it? my adb is not working
There are currently 2262 users online. 2 members and 2260 guests.
