Core 1080p no overclock.
NEOMODE CUSTOM ROM 1.3 - MK802IV, UG007B, CX-919, MK809III with AP6210
I have an issue with my CR9...
I'm currently using sam's 720p 1.8ghz with 800mhz gpu and 1400mhz ram (the cpu is underclocked to 1.6ghz) and I'm experiencing screen "failures". The stick does not reboot or shutdown but the hdmi signal is lost and recovered very fast almost like I removed and put it back. I already tried 2 different HDMI extensions but the problem persists... anyone with this problem?
800 MHz will not Work for all Devices also the Ram Speed.
Try another Kernel from Sam321.
Neomode
Originally posted by neomode View PostI would say this is too much for your Stick. Have you cooled to your CPU ?
Neomode
But which kernel would you recommend? I would bee happy with one that can play Full HD videos on XBMC. I tried all 1080p kernels but they lag too much (maybe XBMC problem, since mine is the August monthly build) so I went for 720p with overclocked GPU...
I really wanted to try a 1.6GHz CPU with 1000Mhz ram and GPU 600 Mhz (1080p and 720p versions)... but there are none...
Tronsmart CX-919
I want to thank neomod for his ROM as it is the only one that will work on my device. I thought it was bricked after trying to flash the CX 919 firmware that was provided by geekbuying and the CR from finless. I am using an the 720 OC at 1.8/800/1400 with no problems or over heating. I tried the 1080 but the screen would not display properly, for example the play store under my apps they were all on top of each other and the details unreadable.
AW: NEOMODE CUSTOM ROM 1.3 - MK802IV, UG007B, CX-919, MK809III with AP6210
Originally posted by Borincano View PostI want to thank neomod for his ROM as it is the only one that will work on my device. I thought it was bricked after trying to flash the CX 919 firmware that was provided by geekbuying and the CR from finless. I am using an the 720 OC at 1.8/800/1400 with no problems or over heating. I tried the 1080 but the screen would not display properly, for example the play store under my apps they were all on top of each other and the details unreadable.
For this you must change the DPI in build prop from 160 to 240.
To do this you can use a build prop editor from play store.
Neomode
Hey I have a question: Video Playback seems to be pretty good for me even in 1080p. But I have these strange slowdowns (1-2 full seconds) that occur every 15 seconds or so. Is that a common/known problem? Because I would guess that this has nothing to do with the general performance of the stick as that should be a constant low framerate or am I wrong? Because I could have sworn I did not have these with other Firmwares. I have a CX-919 with a RAM OC'ed kernel (its kinda the same with standard).
Thanks.
hello all and thanks neomode for suporting the cx-919!
I have a new CX-919 that the PCboard inside says Ver.2.0, and would like to install your 720 OC 1.8/800/1400, but would like to know if this ROM works better or not than the latest Finnles ones?
Neomode, You mentioned that a new update of the Rom will come this week, whats new ?
Originally posted by ulises1954 View Posthello all and thanks neomode for suporting the cx-919!
Re: NEOMODE CUSTOM ROM 1.3 - MK802IV, UG007B, CX-919, MK809III with AP6210
Hi!
I have a problem with my MK802IV and need a little help. First I flash the Vondroid_RKM_beta ROM, but not solved the video lag problem. After I flash this 1.3 ROM, with the tool, from zip.
1: erase idb
2: flash ROM
But write "download idb failed" message, und tsüsss. Here is the screenshot:
My stick is dead, or "only" krank? What can I make? I have the original rom, dmesg, CWM backup from Vondroid ROM, Batch tool, Flash Tool, Win, and Linux.
Sorry, for my bad english!
GT-I9100 (Wanam14.1-Dori8.41), Measy U2C (Finless1.7), MK802IV (AP6210, ROM???)Last edited by Somatom; 28 September 2013, 20:48.
There are currently 1920 users online. 1 members and 1919 guests.
