i tried cx919 1080p stock kernel it went into boot look now i am back on nexus custom rom.
NEOMODE CUSTOM ROM 1.3 - MK802IV, UG007B, CX-919, MK809III with AP6210
Re: NEOMODE CUSTOM ROM 1.3 - MK802IV, UG007B, CX-919, MK809III with AP6210
Originally posted by angelboy View Posti installed on cx919 my wifi was not able to connect to ssid. i have wpa2 setup after entering password it is just getting stucked at obtain ip address.
Signature? Signature!
Originally posted by JugsteR View PostI have the same experience. Is there such a thing as a custom kernel with working WiFi?
Signature? Signature!Last edited by bloatman; 18 August 2013, 11:29.
Still no Wifi
Overall user experience - slower than other stock or std roms
Display - was not full screen somehow even after full settings
Video - no problems as dint observe any difference that earlier roms
wifi - DOES NOT WORK (neither has it worked after I rooted from original factory ROM)
BT was ok
Rest ok...No complaints. Any way where we can fix the wifi ?
Thanks once again..
memory Problem
Hi neomode,
I have a memory problem with my 809iii stick.
Original firmware: 2GB RAM 8GB Flash
With Your rom I can only see
1 GB RAM 5GB Flash
What can i do to use all memory built-in ?
Thanks in advance
EDIT:
After reboot I can see 2GB DDR RAM, but flash space is limited to 0.98GB Internal, 5.27 GB NANDLast edited by pirmar; 17 August 2013, 01:03.
Originally posted by pirmar View PostHi neomode,I have a memory problem with my 809iii stick.Original firmware: 2GB RAM 8GB FlashWith Your rom I can only see1 GB RAM 5GB FlashWhat can i do to use all memory built-in ?Thanks in advance
Noob Question
Hi Community,
trying to flash an MK802IVS from Amazon with Neomodes 1.3 image.
After using rkandroidtool the stick does not boot any more. Blue light stays off.
Recovering using Rikomagic Images from rikomagic.de by using rkbatchtool brings stick back to life.
Still eager to test neomodes stuff. Followed every how to in this board, but no luck.
Also tried not to flash the rk3188 loader (unchecked in rkandroidtool), but also no luck.
Any idea what i am doing wrong? Is there a way to convert the ing files into one to be flashed by rkbatchtool (i hope it will work then)?
TY
ebeneezer
Noob Question
Originally posted by neomode View Post
Thank Neo for your quick reply, my S/N is 1305050197 - so i guess i got an old version stick.
Just to make sure: My stick did not at at all - just blank black screen and no power led. Seens odd that this has to do with the wifi chip.
I will flash the older kernel and let u know.
ty
ebeneezer
Noob Question
Originally posted by ebeneezer View PostThank Neo for your quick reply, my S/N is 1305050197 - so i guess i got an old version stick.
ty
ebeneezer
Still no luck - Stick is dead after flashing. Reflashing with Firmware für MK802 IV S v1.3 from
Diese Website steht zum Verkauf! rikomagic.de ist die beste Quelle für alle Informationen die Sie suchen. Von allgemeinen Themen bis hin zu speziellen Sachverhalten, finden Sie auf rikomagic.de alles. Wir hoffen, dass Sie hier das Gesuchte finden!
restores stick to life.
I don't get where my mistake lies.
There are currently 1935 users online. 1 members and 1934 guests.
