LibreELEC Kodi Krypton does auto everything both Audio and Video wise and is superior for local media playback vs anything else.
[Firmware Stock] OTA MECOOL M8S PRO L ANDROID 7.1 AMLOGIC S912
Originally posted by gfantom7 View PostI would like to ask if I can install the proper 7.1 android nougat version to the Mecool m8s pro L android tv version. If yes I would apriciate some small details.
I am sorry in advance if you find my question stupid, I have ignorance about this matter. Thanks..MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
I am just asking if I can change this stupid tv version of android 7.1 and use a simple version like the m8s pro has. If one of your custom ROM's has this feature, I would be happy to use it, thank you Magendanz..Last edited by gfantom7; 31 October 2017, 12:32.
Originally posted by gfantom7 View PostI am just asking if I can change this stupid tv version of android 7.1 and use a simple version like the m8s pro has. If one of your custom ROM's has this feature, I would be happy to use it, thank you Magendanz..
This version has the Google Play Store for Android TV, but no Android TV Launcher (a.k.a. Leanback Launcher). If you want the full Nexus Player experience, then just install my Nexus TVStock custom ROM for the M8S Pro L. http://freaktab.com/forum/tv-player-...android-tv-7-1
a new member here and i really need help.. have bought for a friend a meccol m8s pro L and i installed the nexus rom on it.. but ifind it constantly freezes.. i want to take it back to the original firmware but i have been pulling my hair out trying to do it.... there is a hole at the bottom of the box but am sure there is no reset button there.
burn card maker doesnt recognize the file i downloaded (M8S_PRO_L-ota-20170918.111557.V0619)
the guide at geekbuying is of little help to me its not very clear.
can someone please guide me in a step by step on how to reflash it
thanks in advance
Try installing this in TWRP: https://1drv.ms/u/s!AoqocX31ecnXgaU8rdh-8u4SJGjxCA
It fixes a bug in the OEM firmware install script that reads the environment (build.prop) from the recovery partition instead of the system partition. It will allow you to roll back to the OEM firmware from TWRP.
thanks for your very quick reply but i cant find the twrp recovery on this nexus rom is there another way ??????/ or do i need to download this twrp tool if so from where... and do i need to unzip that file or rename it ( as it is a zip file)
sorry if i am asking noobie questions
From the Terminal window, just type "reboot recovery". There are also apps you can install that will reboot to recovery. (Sadly, you can't hold down the reset button on the M8S Pro L because they didn't solder on the damn switch.)
As for the freezing, have you been tracking the overheating issues on this forum? Maybe some thermal grease can fix the problem.
once more if i may....... how do i use a terminal window..... and name of an app to reboot to recovery...( do i just pit the whole zip file on sd card or rename the zip)..... i really dont want to open the box as it is not mine... i am doing this for a friend.... if it dont work i will need to shoulder the expensse of a new box for him
thanks so very much for your replies
No expert here !
I would download the Fixed version linked above by MDz
All the Terminal apps in ATV Playstore are useless IMHO
I would install Aptoide app using Chrome/Google
I would install Terminal app from Aptoide
Run Terminal and type in - reboot recovery <SEND>
In Recovery choose Wipe Data
Do not need to unpack file just put on USB/SD
In Recovery choose Update from Ext
Choose file
Choose file
once again thanks to both yourself and Magendanz
The one I tried was just called Terminal and has 3K downloads on Aptoide uploaded by austroid
Black screen icon with simple >_ in VDU green
reboot recovery then click the SEND button
There are currently 2252 users online. 3 members and 2249 guests.
