I would like to have a rom that have a normal playstore and one that can solve my hang problem. my current ROM is not compatible with kodi xbmc original. According to my supplier, i have to use the pre installed tv centre but that one also gave me the same problem which was hang problem. i feel devastated now. i saw Guest 's post and clicked it, but there was a lot of firmware there and i don't know which one should i download. Another problem is,i only know how to update firmware using OTA, tried using usb burning tools but was unsuccessful. Can anyone help me..
[Firmware Stock] OTA MECOOL M8S PRO L ANDROID 7.1 AMLOGIC S912
Hi guys,
Thanks to all, finally i successfully downgrade my M8S PRO L from 20171127 firmware to 20171109, but this firmware use new launcher in which RAIPLAY app don't start.
Netflix works fine and in full screen but now i would like to back to latest firmware with MECOOL launcher.....
I download 20170918.... fw , now my question is:
1. do you know if this firmware (20170918...) use mecool launcher?is this latest firmware that we have?
2. is there a way to install only TWRP without install a Magendaz firmware? i successfully downgrade my M8S PRO L with a double action:
- install [ROM] Mecool M8S Pro L Stock & Nano Nexus ROM (Android 7.1)
- run into recovery mode
- wipe cache,etc
- install fixed M8S PRO zip firmware from udisk
so is this M8S_PRO_L-ota-20170918.111557.V0619 latest firmwarefor our M8S PRO L?
thanks
Marco
No, we've had the following OEM releases since that one:
20171109.180937.V0928
20171117.164057.V0928
20171127.165619.V0928
20171208.110230.V0928
That last one I actually rejected as a foundation for custom ROM releases, since it didn't add any new features or fix any bugs. It just completely disabled stuff like sleep and Google Cast that had open issues.
The burn package (.img file) must be flashed with Amlogic's USB Burning Tool or Burn Card Maker. They're a proprietary Amlogic format, and not the same as the raw partition images that you can flash in TWRP, despite having the same file extension.
From the updater, just use the OTA update (.zip file).
Magendanz please, where i can found stock firmware 20171208.110230.V0928
i try to search in internet or in this forum but i don't find it, please can you send me a link?
in firmware 20171127.165619.V0928 netflix have problem to play movie in fullscreen...remember my picture?
i would like to test this last....
thanks in advance...
Marco
Also, is GoogleCast working for anything? My understanding was that GoogleCast feature was totally not working on ATV box except Nexus Player & Shield TV.
If it's the case, keeping those 2 features isn't useful.
Guest asked to have this posted on a bit of a break
A Patch not full update:
Note that it's an update that needs to run on 20171208.110230.V0928.
(An incremental update, not a full block-based update)
https://mega.nz/#F!DNFVBQaS!JYRMgTsfUtZW1Lh_OrUSCQ
Originally posted by trebor View PostGuest asked to have this posted on a bit of a break
I need it to apply the patch so I can then pull the patched files for use elsewhereLast edited by tillaz87; 21 December 2017, 09:31.
This should do the trick,
I needed to ask Guest as well
https://mega.nz/#F!uctxyIgL!qs30ihQq4iskqSriDSgyCA
vdeostrong must know as well as they try to hide it by turning animations off and others set to 0.5x not goodLast edited by tillaz87; 25 February 2018, 23:45.
There are currently 3616 users online. 0 members and 3616 guests.
