[Firmware Stock] OTA MECOOL M8S PRO L ANDROID 7.1 AMLOGIC S912
Originally posted by trebor View PostThink you will find it a mix of Firmware and hardware with Hi temps
Idle temp here is about 10c too high as compared to some good 912 firmware/hardware me thinks
Idle here is about 55c/130F +/- should be closer to 40c/100F +/- at idle.
Heat sink here is on Solid, may try alloy plate and thermal pad underneath and some thicker Feet/Pads to get it up a little higher.
Edit: The box does not feeling hot, warm but not hot.MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
I did this mod to the yoka KB2 many over 12 months ago it was a hotty, Luckily it had a metal so cooling was easy
Click, More to do with software background task and may be a little hardware
Thanks for posting that OTA update (V.928), Trebor. I tried it out and - speed-wise - found it a noticeable improvement over the earlier factory rom. Snappier around the menus, with some nice extras like selectable display color space. Leanback launcher too. Didn't notice any heat issues after running 4k YouTube videos for a couple of hours. However, I did find network bothersome - specifically more buffering of high bitrate clips and too many dropped connections. These hiccups happened on both 5ghz wifi and LAN on the same connections I've used previously without issues. Didn't test further, but simply reverted to Magendanz ATV, where all is well once more... Waiting to see if M decides to update his fine rom with the new base -- that would be the way to go.
Originally posted by Zahir View PostThanks for posting that OTA update (V.928), Trebor. I tried it out and - speed-wise - found it a noticeable improvement over the earlier factory rom. Snappier around the menus, with some nice extras like selectable display color space. Leanback launcher too. Didn't notice any heat issues after running 4k YouTube videos for a couple of hours. However, I did find network bothersome - specifically more buffering of high bitrate clips and too many dropped connections. These hiccups happened on both 5ghz wifi and LAN on the same connections I've used previously without issues. Didn't test further, but simply reverted to Magendanz ATV, where all is well once more... Waiting to see if M decides to update his fine rom with the new base -- that would be the way to go.MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
or the pther apps
Please help with the issue. Was running Mecool M8S Pro L TVStock Nexus ROM (Android TV 7.1) on my S912 L 3G/32GB was working fine and attempted to upgrade to latest OTA firmware from TWRP and getting errors; also will longer load any OS. Only have working TWRP.
Tried using all related firmware to S912 with no luck. I'm new to this but I'm assuming partitions may be the issue. Please assist.You may only view thumbnails in this gallery. This gallery has 1 photos.1 Photo
The OEM OTA update has a bug in the updater-script that prevents it from installing on TWRP custom recovery. I'll publish a fix when I return home, but if you're in a hurry you can edit the Edify script yourself. Just comment out the lines with the getprop() commands which abort if device doesn't match what is expected or build date is newer than allowed.
You'll need to unpack the .zip file and compress it when done, keeping the same file hierarchy. It will no longer be signed with the correct signature, but TWRP allows you to install without that as long as the Verify Signature option is left unchecked.
Ref: https://source.android.com/devices/t...nside_packages
Is there a list anywhere of the actual changes and fixes in the latest OEM firmware update?
Anyone have screenshots of the new launchers it comes with?
Being new to tv boxes, i would assume the easiest way is to download the OTA update, copy it to microsd and point to it via the OTA update app ?
I dont really want to try the whole pc flash method and stuffing around with the tutorials i have seen.
How come this is not available direct from them when you press check for updates?
Cheers
Originally posted by trebor View PostFirmware OTA :
M8S_PRO_L-ota-20171109.180937.V0928
Thanks to those in the know....
Also Found and blog.geekbuiyng
PC Flash Firmware
M8S_PRO_L-NHG47L-20170918.111557.V0619.
OTA Update Firmware
M8S_PRO_L-ota-20170918.111557.V0619
Thanks :^)
Originally posted by RobertK View Post
If I put the update on a USB and go to the update app on the box do I have to check off the 2 boxes for wipe data and wipe media for it to update??
Thanks :^)
Note have fixed the overheating put a 5v sub fan underneath now running at 50 Celsius running kodi
Had to use Terminal (reboot recovery) to Update from OEM V0619 as the stupid UPDATE App just switched Off each time and never installed ??
New V0928 is running no cooler than OEM V0619
New V0928 has no APP Drawer, like a great Magendanz ATV ROM has, so I have had to install SideLoad Launcher and that is not as neat to my mind !
Some useful (and not so useful) apps now have Leanback Icons (DRM etc.) but I liked to have my least used apps hidden in the drawer - Now they sit in the long line all the time !! I think I would have to uninstall them and reinstall the old pre-ATV versions if I could be bothered ...
I def. prefer the Magendanz implementation of ATV.
OEM also missing the Double-Click HOME function to get a Recent App Switcher thingy !Last edited by P.X; 14 November 2017, 18:30.
Guest
Just FYI, I was able to recover my original bricked M8S Pro L using Mask ROM mode and this .img file posted by geekbuying : http://geekbuying.mediafire.com/file...1557.V0619.img
Checking with DRMInfo, both the Widevine L1 and HDCP 1.x keys were intact after the recovery. (We had some concerns that the hard eMMC reset might wipe those, but it seems those concerns were unfounded.)
NOTE: This .img file is for 20170918.111557.V0619 OEM firmware, but I'm uploading 20171109.180937.V0928 now.
There are currently 2502 users online. 0 members and 2502 guests.
