[Firmware Stock] OTA MECOOL M8S PRO L ANDROID 7.1 AMLOGIC S912
Originally posted by Doktor-X View PostThat last rom is strange no mecool launcher and gui is so big some sort of dpi problem
Originally posted by tomtom99 View Post
It has 320 density in build.prop, i changed it to 240 so it looks better, for tv screens, low density, high watching distance, you want it be less, maybe i will even lower it more, need to check it.
Marco
Well i just edited it with es file explorer, you need to change the line
ro.sf.lcd_density
But i changed 320 to 240.
Save and restart, but be careful if you by accident change anything and it will be wrong then it wont start again.
But actually i found out there is an option in settings to change this without editing build.prop, go to more options, go to display and there it is, display size with a slider.
There is also a separate option to change the font size if you don't like the size after display size change.
Originally posted by tomtom99 View PostWell i just edited it with es file explorer, you need to change the line
ro.sf.lcd_density
i will check immediatly this option....
Marco
Ok i'm glad to inform that i have found a way to enable live wallpaper on the box if it is missing. (not all roms/oems have live wallpapers, but i wanted it, it looks cool)
First, you need to go here https://www.apkmirror.com/apk/google...lpaper-picker/ and choose your android version picker, my is OEM 7.1.1 but it probably will work with any 7.x apk.
Second, everywhere i read a tutorial they said to place it in system/app directory to make it a system application, but this don't work on my box, picker will just crash the moment you want to set a live wallpaper, probably this way it will not work on this boxes, so out of ideas trying to do it manually i found a tip, i installed it normally and then changed to a system application using an app called "lucky patcher" (official dl site https://www.luckypatchers.com/download/ do NOT use any other site)
So just install the picker, then go to lucky patcher, select that app (animated wallpaper), tools and convert to system app.
After i done that, restarted, it worked. I have also found out that it did put the apk in system directory, but in system/priv-app, so this is probably it, it need to be in priv-app folder not app folder.
I also copied a file to system/etc/permissions/ the file name is android.software.live_wallpaper.xml
Its content is here https://android.googlesource.com/pla..._wallpaper.xml
But i don't know if it is needed, it is some permissions thing, i will yet check if i can do everything again manually and if it will work too, without the use of any app.
Guest
Here's a link to the full burn package for the 20171216.102705.V0928 OEM firmware: http://freaktab.org/581ac9d6b390e622
Note that I've confirmed that the wake from sleep works now...but it's taking about 28 seconds. I'm not sure what they're doing, but it should take only 2-3 seconds.
Originally posted by Magendanz View PostHere's a link to the full burn package for the 20171216.102705.V0928 OEM firmware: http://freaktab.org/581ac9d6b390e622
#132.1Guest commented10 January 2018, 02:25Editing a commentTry this one: http://freaktab.org/4c6101e17e68e78c
Originally posted by turtlegsr View PostMagendanz please, where i can found stock firmware 20171208.110230.V0928
i try to search in internet or in this forum but i don't find it, please can you send me a link?
in firmware 20171127.165619.V0928 netflix have problem to play movie in fullscreen...remember my picture?
i would like to test this last....
thanks in advance...
Marco
There are currently 1935 users online. 0 members and 1935 guests.
