[Firmware Stock] OTA MECOOL M8S PRO L ANDROID 7.1 AMLOGIC S912
i lost text !
on M8S pro L I followed the step to move to android tv, with M8S_PRO_L-ota-20180205.111652.V0928-fixed.zip
everything happened as said on the tutorial, but now I have a blue screen and on it: hold "-" and "ok" while holding the remote near the box,
what should I do, what is this "-" on the remote control?
the remote control is operational, if I press return (below the "-" volume), I leave this screen and find myself on a blue screen, then nothing, but the volume button works, the button also off, I can turn it off, but reboot back to this config screen from the remote
usb keybord and mouse are ok,
how i can do now ?
thanks
Originally posted by yyvon66 View Postla solution thanks
how i can do now ?
thanks
thanks, but yesterday i make that : http://freaktab.com/forum/tv-player-...533#post714533
so it is no more blocked now, but i cannot make anything, neither firefox, neither skype,
so as i don't like this new android tv, so , either i try to put the TVStock Nexus ROMs android tv, either i come back in the origine firmware, but how ?
which difference between http://freaktab.com/forum/tv-player-...912#post673617
and http://freaktab.com/forum/tv-player-...7-1#post676338
i am lost, what i must do now ?
thanks
ps excuse my language, but i am french.
which difference between .zip and .img ?
Originally posted by yyvon66 View Postthanks, but yesterday i make that : http://freaktab.com/forum/tv-player-...533#post714533
thanks
img: flash with burning flash tool or sd card flash tool
I Just recived my M8S_PRO_L , its seems to have last Upgrade, but cant install TWRP via recovery (Signature error). I reflash with M8S_PRO_L-ota-20180205.111652.V0928-fixed.zip, but does not work .
I put the TWRP "recovery.img" on my SD and plug the power with reset button pressed (jumping contacts) but bootloader hangs in "MECOL" screens.
Really I want to disable/enalbe de AMLOGIC root, but cant install any zip with default recovery, always "siganture error".
Any Ideas? Thanks.
Any Ideas? Thanks.
see here how i do with the same M8S pro L : http://freaktab.com/forum/tv-player-...533#post714533
I use your method, open Tv box and jump contacts , I mean that
"wipe data / factory reset
wipe cache partition
apply update from ext
so it must be updating this "update_M8S_PRO_L-V0928_TVStock-20180310.zip"You may only view thumbnails in this gallery. This gallery has 2 photos.2 Photos
Télécharger:- Nano Variante: PAQUET BURN (924MB fichier IMG), mise à jour OTA (476MB fichier ZIP)
- Stock Variante: PAQUET BURN (fichier IMG 1,42 Go), mise à jour OTA (807MB fichier ZIP) <======== this one
- Paquet de brûlure Flash avec Amlogic USB outil de gravure v2.0.8 ou BootcardMaker v2.0.0.2
Originally posted by yyvon66 View Posthttp://freaktab.com/forum/tv-player-...android-tv-7-1
Download:- TVStock Variant: OTA UPDATE (531MB ZIP file)
i'm lost...
i have wrongly updated my mecool m8s Pro L with the file of 27th november of this thread, but now i have the android tv rom!
I was in stock rom from mecool, and i thought that the file of 27th november was an update to stock rom. It turn out not to be!
How can i install the latest stock rom (not android tv version)?
My thanks in advance for the help.
Just for curiosity: I do not understand the advantage of using android tv rom, since i find the configuration not easy. For example: I couldn't delete some apps shortcuts in homescreen and I cannot have the youtube advertisements and recommendations in homescreen because they are not advised for my young children to watch. Is there a tutorial on how to work with Android TV rom?
There are currently 2125 users online. 1 members and 2124 guests.
