[Firmware Stock] OTA MECOOL M8S PRO L ANDROID 7.1 AMLOGIC S912
Originally posted by Lightning69 View PostHi. I'm new to the android TV box and i'm thinking of getting the Mecool M8S Pro L that comes with widevine drm, 4k YouTube Netflix. Will installing this custom firmware result in losing this widevine drm, 4k YouTube Netflix?
Originally posted by Lightning69 View PostHi. I'm new to the android TV box and i'm thinking of getting the Mecool M8S Pro L that comes with widevine drm, 4k YouTube Netflix. Will installing this custom firmware result in losing this widevine drm, 4k YouTube Netflix?MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Originally posted by Lightning69 View PostThank you. So it all depends on what hardware version I will be getting. What do this custom firmware fix and what is not working? Or should I just stick to stock firmware?
I received my Mecool M8S Pro L and the hardware shows S912 3GB 32GB DDR3 LB. So can I flash with this custom firmware? I order 2 units and both units having problem with Youtube app. The Youtube app will hang up all the time. Anyone can advise how to solve the Youtube app crom crashing or hanging up. Btw, the Youtube app can stream 4k youtube video smooth but it just hang up after about a minute.
The other thing is the Chrome app. The Chrome app is default to mobile site but I want it to start with desktop site. I have done a google search and the is a method that requires transfer chrome-command-line file. I try but could not transfer the file because I think the unit is not rooted. There is a install via zip through recovery boot but how do I boot into recovery with the Mecool box?
Originally posted by Lightning69 View PostI received my Mecool M8S Pro L and the hardware shows S912 3GB 32GB DDR3 LB. So can I flash with this custom firmware? I order 2 units and both units having problem with Youtube app. The Youtube app will hang up all the time. Anyone can advise how to solve the Youtube app crom crashing or hanging up. Btw, the Youtube app can stream 4k youtube video smooth but it just hang up after about a minute.
The other thing is the Chrome app. The Chrome app is default to mobile site but I want it to start with desktop site. I have done a google search and the is a method that requires transfer chrome-command-line file. I try but could not transfer the file because I think the unit is not rooted. There is a install via zip through recovery boot but how do I boot into recovery with the Mecool box?MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
At this time don't try flashing anything. As far as YouTube, go into the settings for apps and uninstall the YouTube updates, see if that solves the problem. Been awhile since I used the command line to make Chrome to the desktop mode as default, so I don't remember. I just have to to the settings in Chrome each time I use it.
https://nexus5.gadgethacks.com/how-t...droid-0159709/
Use a reboot recovery app
Boxes are Rooted but may need control app installing
Hi guys. I just received an LB from BG last week and right off it would just hang at the Mecool screen. The folks at BG sent me a firmware link and asked me to try flashing it. I was working my way through this thread and tried lots of things, only to discover that the firmware BG wanted me to flash would have been the wrong one for the LB (they sent me to a link with an old v0928 release) . It doesn't really matter because i never got it to flash, or even start flashing. I did try flashing by shorting the pins with the fw on the SD card and now the Voice remote does nothing. I used to be able to get to the recovery option screen by holding the power button while powering up. Can i fix this?
So, now that I know which firmware to flash (is there a posting with a link to the 02xx version? I have to go back and look...) I need to know how to flash it to the box (presuming the box works at all). I'm unsure which method, if any, might work. Keep in mind that I'm a newb. Thanks for your help
Sent from my LG-H932 using Tapatalk
Originally posted by ZilogZ80 View PostHi guys. I just received an LB from BG last week and right off it would just hang at the Mecool screen. The folks at BG sent me a firmware link and asked me to try flashing it. I was working my way through this thread and tried lots of things, only to discover that the firmware BG wanted me to flash would have been the wrong one for the LB (they sent me to a link with an old v0928 release) . It doesn't really matter because i never got it to flash, or even start flashing. I did try flashing by shorting the pins with the fw on the SD card and now the Voice remote does nothing. I used to be able to get to the recovery option screen by holding the power button while powering up. Can i fix this?
The other thing is the Chrome app. The Chrome app is default to mobile site but I want it to start with desktop site. I have done a google search and the is a method that requires transfer chrome-command-line file. I try but could not transfer the file because I think the unit is not rooted. There is a install via zip through recovery boot but how do I boot into recovery with the Mecool box?Last edited by adrdidi; 21 July 2018, 10:46.
Originally posted by ZilogZ80 View PostI will try. At this point all the box will do is boot to the Mecool screen, will shorting the pins make it visible to the USB burning tool.?
There are currently 2668 users online. 2 members and 2666 guests.
