Thank you
[Firmware Stock] OTA MECOOL M8S PRO L ANDROID 7.1 AMLOGIC S912
Originally posted by LilSnoop40 View PostGood day, i have a mecool box with the nexus rom loaded on it. how do i add apps to the home screen that show up in the app drawer, for example i got some apps from aptoide or downloaded via the browser.
Thank you
Hi Guys,
i upgrade now to an OTA update for my Mecool M(S PRO L - LB version , now my firmware is:
20180803.173707.V0213 - Android 7.1.2 - NGH47L
I check DRM with DRM Info and lost Microsoft DRM support, is this important?
with oginal firmware
20180417.150752.V0213 Microsoft DRM was supported!!!
thanks
Marco
Originally posted by JulioThosi View PostPlease, I need some help!
I'm install the SD Firmware 11-17 and after this the wifi and the bluetooth doesn't work. My box is Mecool m8s pro L.
thanks
you need to see bottom stick it should say LS/LQ/LB on it
this will help us determine what version of the box you have.
Originally posted by bayard0 View Postyou installed the wrong firmware for your box.
Hi, im new user on this forum but i tried to read about my problem and not found a clear solution.
I had recive my m8s pro l (version LB with no BT remote), he has installed non-ATV firmware(7.1.2 NHG47L-20180806.095310.V0213) and i will like try to install an ATV version. The problem i found reading its that i cant install custom firmware because i will lost wifi and bt and im not sure if i can install version of LB with BT because i dont know if its supported. Can someome says if exists any firmware from my M8S Pro L or i must stay whit this non-ATVRom?
Thx in advance.
PD:We (LB users) need a custom rom to left this problems ago.
PD:Sorry for my bad English.
Originally posted by Nedriem View PostHi, im new user on this forum but i tried to read about my problem and not found a clear solution.
Thx in advance.
Interesting, it means LB (normal remote) version has new firmware finally ? There is not custom rom for LB (normal remote) version yet. So stay with this rom only.
Originally posted by Elkhan Gaybalizada View Post
Hi, I have also the same Box with LB. Could you please share the link to the correct ROM? I have also the same problem. ThanksLinks to the LB Image files on here:1. M8S_PRO_L-NHG47L-20180316.143701.V0213.IMG -http://freaktab.org/a28c3f52268572bb
2. M8S_PRO_L-NHG47L-20180417.150752.V0213.IMG -http://freaktab.org/8e1ecd22568550f2
**Posted first by Wanderer190, 05-18-18 in http://freaktab.com/forum/tv-player-...e-screen/page2
There are currently 2961 users online. 0 members and 2961 guests.
