I do not know how to install it, is it an OTA? is this the version LB / VOICE REMOTE CONTROL ???
[Firmware Stock] OTA MECOOL M8S PRO L ANDROID 7.1 AMLOGIC S912
Originally posted by japseye View PostLooks like OTA, Pro L voice remote.
Taken from metadata
ota-required-cache=0
ota-type=BLOCK
post-build=Amlogic/q20x/q20x:7.1.2/NHG47L/20180316.115110.V0213:userdebug/
post-timestamp=1521172266
pre-device=M8S_PRO_L_4335
Originally posted by philman View Post
so this is an old version of the firmware!
It's an .img file that has been compressed. I used 7Zip to decompress and then USB Burning Tool v2.0.8 to flash it.
It's been over a week since I've asked for help and I'm constantly being ignored.
I'm sorry for very likely being a retard but I've read this entire thread and I can't find an answer myself.
"I have the Mecool M8S Pro L (LQ version) and can't figure out which OTA firmware is the latest.
I have the 20171216.102705.V0928."
Can anyone please answer my question? Can anyone please point me in the right direction?
Originally posted by paposeco View PostIt's been over a week since I've asked for help and I'm constantly being ignored.
Originally posted by Mainspring729 View Post
I am using this with the LB version, and everything works fine. It's a newer OEM release: http://freaktab.org/80bd15e188e655f2
Thank you for your explanation. Do you know if the Mycanal APK works with this firmware ??? Because the image freezes with this APK Mycanal on the firmware M8S_PRO_L-ota-20180913.182655.V0213.zip
Guest
Yeah, you're ending up in OEM recovery and it thinks it's installing an update, not the Amlogic burn package. Amlogic's BootcardMaker (a.k.a. Burn Card Maker) requires an Amlogic burn package (.img file), so you've got to uncompress the file I've linked first.
In this case, the OEM recovery seems to be trying to flash "Megatron-S812-M8S-M9.zip" on the USB flash drive, which I'm pretty sure isn't what you intended.
There are currently 3862 users online. 2 members and 3860 guests.
