[Firmware Stock] OTA MECOOL M8S PRO L ANDROID 7.1 AMLOGIC S912
#361.1Guest commented14 December 2018, 23:05Editing a commentIt probably won't support the old QCA9377/LTM8830 wireless chipset. If they were clever, they'd create an All-in-One firmware like Shiningworth did that supports multiple wireless chipsets. It would save their support guys (and customers) a ton of headaches.
Originally posted by japseye View PostGuest I have tried downloading this file twice. It is corrupt!
"There's a newer OEM release (20181018.101400.V0213) here: http://freaktab.org/80bd15e188e655f2"
Hello guys im searching a new rom for my M8S Pro L LQ, too. But cant find anything for the LQ Version. Can anyone help me?
because it crashes after two days of continuous operation.
I hope this Data of my Box helps:
Android Version 7.1.1
Kernel Version: 3.14.29 Mon Sep 18 11:18:07 CST 2017
Build: M8S Pro L -userdebug 7.1.1 NHG47L
20170918.111557.V0619Last edited by Mess91; 15 December 2018, 15:40.
Originally posted by bubblegum57 View PostI have just installed OEM release (20181018.101400.V0213) to my Mecool pro L the interface has changed, it works. Netflix seems to be working, not sure if it will pack up with the next update.Last edited by sweetnonso; 16 December 2018, 06:47.
Originally posted by maxou2 View Post
Hello! This firmware is for which version the Mecool? That with the voice remote? And how should you install it? Thank you for your answers !!!!
This works for the Mecool M8S Pro L. With Voice remote. I used 7zip to extract the image file, then used the Card maker to burn to micro sd card.
As there is no reset button. I turned off, inserted the sd card, plugged the power lead in, while continually press the context button on the remote.
It then started the update, note, it has a different boot logo, & the interface isn't the leanback launcher
Originally posted by bubblegum57 View PostThis works for the Mecool M8S Pro L. With Voice remote. I used 7zip to extract the image file, then used the Card maker to burn to micro sd card.
There are currently 2848 users online. 0 members and 2848 guests.
