[Firmware Stock] OTA MECOOL M8S PRO L ANDROID 7.1 AMLOGIC S912
- Download the image for your model M8S Pro L to a Windows PC (Google it)
- Download and install the USB Burning Tool on your PC.
- Run the USB Burning Tool on the PC - Select the Language from the middle tab.
- Do NOT power up the M8S media box, but rather plug a USB-A to USB-A cable from the M8S Pro L to the PC
- Quickly press the Menu button on the Media Box's remote (3 bars button). Keep pressing until you see that there is a connection between the M8S and the USB Burning Tool under Device ID.
- In the USB Burning Tool go to File >> Import image ... then press Start and wait until it is finished.
Hi , i tried M8S_PRO_LB-20181018.101400.V0213 on my lb version box but as other attempts fails. It stucks on 7% formatting and then terminates and says as the image.
I tryied with usb burning tool 2.1.6. For long time i have only blue light .
Can someone help me cause the device is useless for 5 months, and it is my first box...
Hi @Mangendaz My device is the MECOOL M8S PRO L (LB) M8S-PRO-LB-20180417.150752.V0213
M8S_PRO_LB-20181018.101400.V0213.img Hi, magendaz, I wanted to ask you what is the difference of these firwares.
Another thing the device gives me the option to update via ote, will all my applications be erased?
It's worth updating
I can't say what is the difference with the other previous rom
but I did flash my box with sdcard /recovery method M8S_PRO_LB-20181018.101400.V0213.img
And a it work perfectly
I can't talk about Netflix HD
YouTube HD work flawless
PS during the flash process the box take some time to get ready be patient.
I have never had luck with the usb burn tool
I used Amlogic burn card maker
I use the format card option
Once "burn"
Unplug power the box
Insert the sdcard
Plug the power to the box
Quickly press menu button on your remote ( question of second here)
Let the box do is job and update it take some time.
Ps
I did download at least 7 differents date rom ?nd only 2 was working properly.
There are currently 2494 users online. 0 members and 2494 guests.
