yes i've the .zip file. you can download it from lucky patcher apk and gta 5 android apk
[Firmware Stock] OTA MECOOL M8S PRO L ANDROID 7.1 AMLOGIC S912
Originally posted by supermal View Post
https://mega.nz/#!lJ4GXabD!DDHIu0xLW...evs5dmsP0KTVHs try this link?this is a twrp back up from my box.you will need twrp to recover your box.use at your own risk but others have reported success in recovering their boxes.this is for m8s pro l box with LB on the sticker on the back of the box.this version has new wifi module and wont work on older box versions.good luck!
Hey guys behave the original m8s pro l when it first came out last year.
Have never updated firmware .What are your thoughts on this one? Can you install from webpage links ?
Is it safe to install via update app and select ota and point to micro SD slot?
Do I need to wipe data?
Never updated these boxes before
Cheers .
Originally posted by Spastro View Post
I dunno if there is newer update
Originally posted by SpastroOh. My bad.
Has anyone tried it .does the SD version just work from that ota app? Do I need to wipe data?
You tube how to use on your TV BOX or similar.
So basically after you burn your firmware to SDCARD on pc, you need to insert sdcard into TV box and make your tvbox boot into recovery then update will install automatically, when TV box reboots REMOVE SDCARD.
Sent from my SM-N930V using Tapatalk
Originally posted by liquid307 View PostYou can try this, I've used it on my vorke to install stock and custom firmware.
Can i not use the update app on the tv box and select local?
How do i boot it into recovery? just leave the sd card in there?
Can i not use the update app on the tv box and select local?MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Originally posted by rlghplay View PostM8S PRO L NON-ATV 20180417.V0213 version or M8S PRO L NON-ATV 20180316.V0213 Please share it with anyone.
I am using M8S PRO L ATV 20180417.150752.V0213 version and it is very inconvenient to use.
TWRP backup or IMG is okay.
Please.
Originally posted by Magendanz View PostJust for reference, I created a couple of Amlogic burn packages for these two new OEM firmware releases:
M8S_PRO_L-NHG47L-20180316.143701.V0213.img
M8S_PRO_L-NHG47L-20180417.150752.V0213.img
Not fully working for earlier HW
There are currently 1673 users online. 0 members and 1673 guests.
