Without a reset switch, it's considerably easier now to use the OTA update, but you'll find this useful if you ever need to recover the box after a bad flash.
[Firmware Stock] OTA MECOOL M8S PRO L ANDROID 7.1 AMLOGIC S912
Guest
Here's the burn package (.img file) for the latest release: M8S_PRO_L-NHG47L-20171109.180937.V0928.img
Originally posted by Magendanz View PostHere's the burn package (.img file) for the latest release: M8S_PRO_L-NHG47L-20171109.180937.V0928.img
and then i have TWRP recovery installed afterwards?
i did not have yet my box, but want to be informed before, thanks
#63.1Guest commented15 November 2017, 09:54Editing a commentNo, for the burn package you need to use Amlogic USB Burning Tool or BootcardMaker. Only the OTA updates (.zip file) can be used for local updates using the Update app.
My Nexus custom ROMs for this box do come with the latest TWRP Recovery, though. You'll get it with the OTA update (which can be installed from the Update app) or with the burn package.
Originally posted by P.X View PostHi,
Had to use Terminal (reboot recovery) to Update from OEM V0619 as the stupid UPDATE App just switched Off each time and never installed ??
New V0928 is running no cooler than OEM V0619
New V0928 has no APP Drawer, like a great Magendanz ATV ROM has, so I have had to install SideLoad Launcher and that is not as neat to my mind !
Some useful (and not so useful) apps now have Leanback Icons (DRM etc.) but I liked to have my least used apps hidden in the drawer - Now they sit in the long line all the time !! I think I would have to uninstall them and reinstall the old pre-ATV versions if I could be bothered ...
I def. prefer the Magendanz implementation of ATV.
OEM also missing the Double-Click HOME function to get a Recent App Switcher thingy !
There is a new firmware update:
Filename: M8S_PRO_L-ota-20171127.165619.V0928
URL: https://mega.nz/#F!uZFCxaLK!8xhrgRBGBObYPFakC-0X4A
Source: email from VideoStrong
And if the issue wake from standby is also resolved with this new rom?
Originally posted by trebor View Post
and the other issue was the wake from standby
thanks
There are currently 4738 users online. 1 members and 4737 guests.
