This is a simple one this time!
Many thks to gearbest for sending me the device to play
Many Thks to my beta tester trebor
READ THE BUGS SECTION FOR UNNECESSARY QUESTIONS!!!!
NETFLIX FHD (ANDROID TV VERSION ) ONLY WORKS ON L1 BOXES, SO IF YOURS IS L3 YOU KNOW WHO TO BLAME... NOT ME FOR SURE...
Changelog V1:
- Based on latest ota 20171013
- Cleaned lots of stuff...
- Added TWRP
- It should have a better cpu usage/ram.
- Cpu temp should also be better.
- Unrooted ( Yes now you can install magisk or whatever you use to root, use the included update app to flash it! )
- General optimization and how the ram is used, should better now.
- Permissions fixed.
- Double press on Home button bring the APP Switch Menu ( App Kill Menu)
- Status bar Auto hide ( Dont ask for Navigation bar because you wont get it )
- Working ATV google remote control!
- Netflix FHD Android TV app, install from Playstore ( Only on L1 boxes, on L3 ones is needed to sideload the mobile version and of course it will be limited to SD only )
- 4k Youtube support!
- Updated DTV App to the latest one.
- FTMC Build 31.
- Some audio mods.
- Settings menus working ( VPN can be added... )
- Added lots of Kl's
- initd.d support.
- Added google cast, ( Will only work with youtube... )
- Xbox360 wireless Gamepad, original and Chinese clones?!(well it works with my clone adapter...)
- PS3/PS4 gamepad support(only with cable...)
- Added Dragonrise USB HID game controllers.
- Optimized some animation stuff!
- And other little stuff...
- And of course all the other ATV mambo jambo...
Bugs V1:
- I bet you guys/girls tell me if they are more
Want to buy me a beer?
Download:
- DOWNLOAD HERE SCV1 ATV ROM
- MD5: 9DFD1B2258FD3A8DABCAB51251FAF8F3
Install instructions:
- Open usb burning tool, load the rom. (DON'T do "Full Erase"... or tick the "Overwrite Key")
- 1º - OTG port its the usb port near the sdcard the upper one
- 2º - Press the reset button and add the usb cable and leave it pressed (you need it for step 3...)
- 3º - Release and press again the reset button quickly and then connect the power cord.
- 4º - Flash....
Where to buy:
1º BOOT TAKES AROUND 6 MINUTES!
THIS ROM DELETES ALL YOUR DATA SO DO A BACKUP!
USE AT YOUR OWN RISK!
Enjoy it!
Here is a Video...
