[ROM] Mecool/Acemax KIII PRO SCV1 ATV ( Android Tv Version )
Hi, I installed this mod, and it's great, I'm very happy with it. Only having a minor issue with it. When playing youtuve v?deos on the android tv youtube app, most of the v?deos show in only a small square square in the center of the TV, using about half the size of the screen, the rest of the user interface of the app show in normal size. If I use the non android tv app of youtube, everything is fine.
Good morning. My question is this: For this Rom, the hidden menu on the DTV to put OSCAM servers is activated by dialing 1,1,1,1,1,1? My other question, Amazon prime video can be run on the android tv version or does it have to be the normal application? I have a Mi box S and I have loaded the nvidia shield apk and it works fancy ... but to this box, with the original firmware no.
Hi Superceleron,
First, I love your firmware for Mecool KIII Pro Hybrid ATV. Actually I have a Meecool Pro Hydrib S9123G 32G DDR3-D. The only issues I have encountered are related to the following applications:
- Google Play Films: I can open the app but there is an error when I try to play a film. There is an error message "Video format not supported". When I update the app to the lastest version of Google Play Films for ATV, the error changes to "Unexpected error!"
- Amazon Prime: I can open the app but it shows an error. "Unable to play"
- Netflix (a classic!): Unable to contact the servers.
For sure I have an account for all 3 providers. When I install the version of the APP for a "normal" android (but I need the mouse), Amazon Prime and Netflix work. Not Google Play.
Do you have an explanation for that? Do you now how solve it or make them work under android TV version?
I've installed codecs (for Google Play), updated Google Services, installed thrid party players (MX players, VLC, etc.) just in case there was a concern with the plugins... no way.
Thank you for your prompt reply
There are currently 4704 users online. 1 members and 4703 guests.
