If yes, how can it be installed? Because USB burning tool needs the reset button to be pressed when try to connect and this box doesn't have one.
[ROM] Mecool/Acemax KIII PRO SCV1 ATV ( Android Tv Version )
Originally posted by tombraga View Postsuperceleron this rom also works with the Mecool M8S PRO L
You will make something for my refered box Pro L de Mecool? (Acho uma box muito interessante, comprei anteontem)
I have all your roms on my 3 boxes Alfawise H96 Pro+ and like it very much, Missing something similar for this Mecool box.
Im still thinking if i will make anything for it or not (yes i do have it here)
i needed one more box and the reason, that i got also a "bad box" i bought now the Mecool and a SC rom would be great on it...
The problem is, this box has no reset button, so we cannot connect easily with usb to pc, only opening and solding something there, this i dont know to do.
Would be cool, if you make here something. When do you think you will decide it? I saw your comment now for the Alfawise H96 pro+ box and i understand this (made a comment there), really confusion with the box.
Well that is why i still dint touch it... 90% of the ppl out there dont know how to solder correctly etc... i will think about it!
Some Amlogic bootloaders such as the Beelink GT1 and Shiningworth All-in-One for Amlogic q201 reference board don't require you to press the reset switch
Perhaps you can just contact Videostrong to ask if they can change it also?
I saw this comment:
So im not even going to try it!
My netflix isn't outputting to 5.1? Stays as stereo?
i have updated to this rom as no luck with other ROM, worked fine, when I go into video settings (press f4 when watching a video on netflix) I get 5.5mb/1080p, so widevine is working fine, but audio says stereo.
I have changed settings to always surround, and hdmi raw. It is working correctly with spmc and YouTube. my sound system is Samsung hw-ms650 with sub and rear speakers, and it is capable of decoding everything, apart from atmos I think.
ThanksLast edited by Dandroid534; 27 November 2017, 01:57.
Originally posted by Dandroid534 View PostMy netflix isn't outputting to 5.1? Stays as stereo?
i dont have any sound decoder hw so dunno...
Edit just tested with ps4, and I can get 5.1 option.
Searching a bit more I found the wetek thread,
I had to flash one of either two Firmware patches or the ATV ROM - from @ricardopvz to get 5.1 DD Netflix Audio to my HDMI connected DD+ capable 4K TV:
wetekforums.com ist die beste Quelle für alle Informationen die Sie suchen. Von allgemeinen Themen bis hin zu speziellen Sachverhalten, finden Sie auf wetekforums.com alles. Wir hoffen, dass Sie hier das Gesuchte finden!
Both of these are easily done from Android Recovery with a USB stick that has the .zip package update on it.
wrxtasy might be the person to ask?
Would be great if you could get it working
Thanks for replying. As I said SPMC is outputting 5.1. netflix will not. Is it confirmed working by anyone on this box? I think I remember with wetek a tweak was needed for the os to get the right information to netflix and co for 5.1.
There are currently 1937 users online. 3 members and 1934 guests.
