[ROM] Mecool/Acemax KIII PRO SCV1 ATV ( Android Tv Version )
Originally posted by geppo View PostA simple question; how add/remove app to/from Home/Drawer?
thanks
First and foremost what a fantastic work!! I recently got the kiii pro and since then been installing numerous roms but this one is absolutely a beaut!! Just as geppo said I am strugling with few things one is getting rid of newly installed apps from home screen and not being able to add the sideloaded apps to the home screen also want to get rid of youtube suggestions from the home screen... also I tried using another launcher but the default one always comes back until I re-run the other launcher even I made the default in the settings... Just few little inconveniences nothing major...
About the launcher... android tv is to have that launcher and that launcher only is not to change guys.. that kills what android tv is if you change the launcher.
I think you guys want a "normal" version of this rom, that im going to make after i do the KI Pro one... on that one you can change launcher etc etc!
Disable recommendations, go to settings/home and is there...
See some youtube videos on how Android TV works, all you need to know is there.
Yes you can install you just cant use the Netflix Android TV version, you need to use the mobile one and you are limited to SD...
A simple question (My box is L3): L1 or L3 is a software or hardware issue? If is software one I have to wait next offcial stock ROM L1?
Originally posted by Maracaibo95 View PostHi Superceleron:
First of all, congratulations for your great firmware.
I have been trying to put a link to DTV in the main bar of the home page but I have not succeeded. It's possible?
If it is not, could you implement a DTV link in the main bar in future updates?
Thank you very much
And no i cant fix it since is not my app...
Open a issue here : https://github.com/ITVlab/TvAppRepo
And hope they can fix their app!
There are currently 2447 users online. 0 members and 2447 guests.
