I hope so much that you make it!
[ROM] Mecool/Acemax KIII PRO SCV1 ATV ( Android Tv Version )
Originally posted by tombraga View Post
superceleron already decided, if you make a rom for the Mecool M8S PRO L?
can you answer please, superceleron thanks
Why after upgraded firmware to android 7.1, My Kiii Pro DTV was unable to detect any TV channels via DVB-T2? I had checked antenna cable which works perfectly. My device was delivered as upgraded firmware one (original firmware based on android 6 and from reviews, DVB-T2 is properly functioned. (Reviews in my country thus territory limit is definitely not my case)
Help !!
PS I had upgraded lastest firmware to android TV ,which allow my device to display streamed Youtube media in 2160p, but DVB-T2 is still not functioned.
Originally posted by iambodin View PostWhy after upgraded firmware to android 7.1, My Kiii Pro DTV was unable to detect any TV channels via DVB-T2? I had checked antenna cable which works perfectly. My device was delivered as upgraded firmware one (original firmware based on android 6 and from reviews, DVB-T2 is properly functioned. (Reviews in my country thus territory limit is definitely not my case)
Help !!
superceleron hi, I've been using the atv ROM for a while now, most things work well, and I know you have said elsewhere you are very busy until the new year, and won't have any time for ROMs until then at the earliest, but i just thought I'd share few things I have noticed:
1. DD+ on netflix doesn't work
2. Spmc crashes when trying switch back to it from the recommendation tab on the home screen
3. I can't seem to make a home screen shortcut for DTV using the very useful addons app.
4. Sometimes after using DtV, and then spmc, the sound gets out of sync on spmc.the only way to fix it is reboot the box.
5. Sometimes after using spmc, when I open DtV the sound is a loud distorted digital mess. The only way to fix it is to force close spmc.
I'm sure that some of these things are not ROM specific, and probably present in the stock rom as well.
ThanksLast edited by Dandroid534; 18 December 2017, 00:30.
Hi, I'm not able to play drm protected content (timvision app). I get the message this device does not support the required DRM scheme
As I can read, the kiii is widevine l1 compliant and the SO is android 6.0.
My box is not l1 compliant and the SO is 7.1. I'm concerned about that my box is a fake mecool box
help me pls. It's not ROM related issue, but I'd like to play TV
ThxLast edited by grzmrc; 02 January 2018, 13:02.
Originally posted by grzmrc View PostHi, I'm not able to play drm protected content (timvision app). I get the message this device does not support the required DRM scheme
Thx
You need to ask Mecool(VideoStrong) for the key but i bet they wont give you...
The 1º and 2º batch of this boxes did come without L1.. i have one here like that!
Hi, can you please help me? I need help urgently
I have the kiii pro and i like it a lot but it stopped working when i tried to flash this rom, appeared an error on the usb burning tool, when i turn on the blue flash appears on the power button but doesnt show anything on the tv, neither the boot logo. I tried the sd card reset method and the usb burning tool but is undetectable on the pc with that program too. What can i do to solve this? Someone help me please
There are currently 4571 users online. 2 members and 4569 guests.
