[ROM] Vorke Z6 / Tanix TX92 Stock & Nano Nexus ROM (Android 7.1)
Originally posted by beastobadness View PostGive this a go...
https://play.google.com/store/apps/d...jcts.amltester
It is still in testing but has never failed me.
Open it and run a GP test. It will search for a play store update, install it and ask you to reboot.
Sent from my ZTE A2017 using Tapatalk
Guest Thanks for your reply.
I just found on the 4PDA forum this https://freaktab.com/forum/tv-player...ck-nano-nexus-
It's your Vorke Z6 Nano 20180119 ported to LPDDR3.
Not sure you were aware of this, and allthough you may have not approved of it, so you know if this file has anything hidden I should be wary about?
I just flashed it on my TX92 LP and it went fine, didn't have the issue when pressing Vision settings in setup wizard.
So far all good, wifi bluetooth all working. In the " about I see Netflix ESN mentioned hoever no netflix installed, can you explain that phrase?
Originally posted by Jancales View PostGuest When I boot up I get the following message, haven't seen this before. This the Nano rom, and i have changed the home screen.\
Is this normal or is there a way to disable it?
There are currently 2387 users online. 0 members and 2387 guests.
