Also remember to make sure that air can circulate from the outside. good luck.
[ROM] Vorke Z6 / Tanix TX92 Stock & Nano Nexus ROM (Android 7.1)
Images
OTA
cheers
update: stock image is working fine in my Tanix TX9 Pro box, stock OTA is also goodLast edited by Alianato; 10 February 2018, 22:26.
Originally posted by Alianato View Post
here they are, the Tanix TX9 Pro/Vorke Z6 Plus images, I had no time to test them all, credit should go to Magendanz
Images
OTA
cheers
I have never tried....
cheers
Originally posted by Luca View Post
Hi, how do I install the OTA stock?
cheers
To reboot into recovery there are several tools in the google shop, the rom is rooted so there is no problem to do it.
I find the latest version of the rom much more stable then before, congrats @Magendanz
Till the moment there is just an annoying problem, when booting/rebooting the resolution is wrong for my TV, so I have to manually set it to 1920x1080@50Hz, I would like to know if there is a setting/work around to force this resolution, did anyone else faced this problem?
cheers
cheers
I have already proceeded to unbricked by shorting pins 5 and 6 of the emmc and reloaded previous image. Now it works again. The resolution problem jumps out every time you do OTA update I read somewhere.
Cheers
I tried to flash with burning tool but the new image no longer starts the box.
Cheers
I burned the new image and then installed the OTA without issues, so at least for me the stock version is working fine (except the resolution thing I mentioned), I did not test the nano image but the process to create it was similar
I am not sure I understood, did you begin to have problems immediately after burning the image or after installing the OTA?
I flashed the image with success but the box does not start. The boot script did not appear.
ok maybe this image file is not good,
upgrading via OTA causes that problem described in the video resolution.
in the updated rom LCD works well?
I am trying the nano nowLast edited by Alianato; 11 February 2018, 22:03.
There are currently 3781 users online. 1 members and 3780 guests.
