[ROM] Vorke Z6 / Tanix TX92 Stock & Nano Nexus ROM (Android 7.1)
Hi Alianto
I am in exact situation as you, I bricked my Vorke Z6 Plus using OTA, I tried unbricking it but so far No luck with shorting the Pin. I tried watching the youtube video you linked and still no go, can you tel me step by step What PIN you shorted and what process you took, USB conection, power conection Etc...
Thank you
http://freaktab.com/forum/tv-player-...279#post688279Originally posted by farshid30 View PostHi Alianto
Thank you
Thank you
Regarding the pins, just freeze the video at second 16s, the pins you need to short are marked in orange, they are the 5-6 if you count from the top-left going down, I had a large needle and I just touched with it both pins 5 and 6, I suppose any good conductive metal will do, for instance a bit of copper wire.
1) I loaded the image (could be the vendor firmware) into the USB Burning Tool and pressed start so it would start immediately after the usb recognized the box
2) With the needle in place I inserted the male to male cable that was previously inserted in my computer into the box usb, you should know the one that works for your box when connecting to the computer if you previously burned a firmware
3) After I heard the sound from the computer warning me of a usb connection I took the needle out and connected the power in order to be sure the box had enough power during the burn operation
this worked for me, hope it helps, good luck
Magendanz commented
12-19-2017, 03:37
Yeah, the OTA update will try to replace the bootloader with the Zorke Z6 version, which is incompatible with the Z6 Plus and TX9 Pro. You could create your own OTA update for the Z6 Plus by swapping out the bootloader.img in the .zip file the same way you did on the burn package.
Hi Guest
When you say "swapping out" do you mean just remove it or to exchange it for another file, I am asking this because if it is to be exchanged I don't know where I would get a proper substitute, the vendor image only have a bootloader.PARTITION file, not a bootloader.img, so I am a bit lost in regarding to that
thanks
Hi
Thank you for your respond, you see my computer recognizes the unit and I hear the sound every time even if I don't short the pin but the loader never starts doesn't matter what I do. I read somewhere that your USB cable could be the problem. mine is too long I think. I have a shorter one but when I use the shorter cable my PC doesn't recognize it at all !!
box <------USB 3.0 cable ---------> + ------------USB 3.0 Extension -----------> PC with USB 3.0 Port
> or < means male
+ means female
regards
Originally posted by JoseM View Postsorry for noob question but how to run TWRP recovery (want to root it using Magisk) ?
With a clip press that button behind the hole and at then plug the power cable keeping the button pressed, the box should turn on and run into TWRP recovery mode
By the way, I am running Magisk and Xposed with magendanz rom
Originally posted by Alianato View Post
There is a small hole in the back of the box, at least in the Tanix TX9 Pro, if not you have to look for it, some boxes have a button inside the av hole
By the way, I am running Magisk and Xposed with magendanz rommay i know which version of Magisk ?
thanksmay i know which version of Magisk ?
The download link to the new version is lower in the thread
http://www.futeko.com/newforum/index...13230#msg13230
Guest regarding your comment: "The bootloader.img in the OTA update and the bootloader.PARTITION in the burn package are the same. Just rename them appropriately."
It worked fine, so now I have my Tanix TX9 Pro with your rom + OTA, I suppose it will work the same for Vorke V6 Plus
Here are the files if someone wants to try them, of course I am not responsible for any damage they could bring to your box
https://openload.co/f/KHxTiWxJr5g/up...L-20171119.zip
https://openload.co/f/eOqZQ_B3LVI/Ne...7L-20171119.7z
https://openload.co/f/ZeQOXukjXz0/Ne...7L-20171119.7zLast edited by Alianato; 20 December 2017, 21:29. Reason: the "update_Nexus_Nano_DDR3_Nano_NHG47L-20171119.zip" is the OTA based from Tanix, should work for Vorke but I did not try it
There are currently 3977 users online. 0 members and 3977 guests.
