[ROM] Vorke Z6 / Tanix TX92 Stock & Nano Nexus ROM (Android 7.1)
Hi, is this rom compatible with vorke z6 plus model? It has DDR3 instead of DDR4. Thank yoy for your kind response.
#16.1Guest commented28 November 2017, 11:17Editing a commentThat's so confusing that the Z6 Plus has slower DRAM and half the eMMC storage as the plain Z6. What moron names these things??
The truth is that I don't have the Z6 Plus, and so I can't really tell you for sure. If you point me to an OEM firmware release, however, I can compare the device trees.
Thank you Magendanz for your answer. At the moment I don't have this box with me but I plan to buy it soon. Is there a way to extract the device tree having the box? Can you point me to a tutorial or give me any information on how to do this? Thanks again.
Well, the easiest way is to just find an OEM firmware that's been posted online. You can, however, dump the partitions using the "dd" command or do a TWRP backup. The device tree (a.k.a. dtb) is actually in the reserved partition, offset by 0x400000. So, the command would be "dd if=/dev/block/reserved of=reserved.img". I can take it from there.
Yes, try the archive site: http://freaktab.org/3~f
OneDrive has been flaky lately, but it's still way faster than the FreakTab file share.
Here is the reserved dump of Vorke Z6 Plus. Is it compatible with this rom?
Well, yes and no. There's one change in the 3G DRAM device tree you sent me, one that fixes a bug in the original OEM ROM (an error in the meson-fb/logo_addr property). I had to fix it on my GT1 custom ROMs for the GT1 Ultimate, but didn't roll out the change to these for the Vorke Z6.
So, there are some other features and refinements that I made for the GT1 release that need to be merged back to these custom ROMs for the Vorke Z6. I'll work on that today, and when the update is posted you should have support for the 3GB Zorke Z6 Plus.
UPDATE: Looking further, it seems the other features and refinements have already made their way into this custom ROM, so I'm just doing a "rolling update" for this device tree fix. So, if you have a 3GB config or Zorke Z6 Plus, I recommend you refresh your download before flashing.Last edited by Guest; 04 December 2017, 04:23.
Originally posted by Oxygen View PostI got it installed thanks for the new links. Is there a root method for this? I tried to install SuperSU but it still says its not rooted.
Originally posted by Jancales View PostI did install the stock variant.
First thing I notice is that the lcd display remains on "boot" instead of switching to time display.
Another question not directly related to this rom.
I notice that I have issues with playing movies through Kodi, where it seems to have problems to handle fast switching scenes, and give a very distorted picture.
This usually happens during the movie intro and closings.
I have this problem on all my Vorke Z6 boxes ( I have a few of them) , with the stock rom and this custom rom, and that is the main reason I wanted to try but it doesn't change anything.
The same movies playing without issues on other soc or on Windows.
Is this a problem specific to the S912 soc or with the Vorke Android 7 firmware?
found this on russian forum may be helpful
(google translate)
Here is my instruction how to run movies with amcodec on 7.1.2
1. We put SPMC with amcodec support https://github.com/koying/SPMC/releases/tag/16.7.1-spmc
2. Turn on amcodec in the acceleration settings
3. Need root. Go to / system / etc / find public.libraries.txt, add to the end libamcodec.so
4. Reboot and enjoy!
(google translate)
Thanks for the response.
I'm sure many people would be thankful to you if you could fix the problem with the codec, and I would surely send you a donation.
How about the LCD display, is there a way around ?Last edited by JoseM; 10 December 2017, 20:45.
Hi Magendanz
I tried this on VORKE Z6 Plus, it takes the flash but nothing happens. it takes the flash fine but I am back to the same z6 plus menu, I have a problem with my Z6 plus, apps shut down on it and goes back to main menu or box reboots, i wanted to try your file to see if it fixes my issues. any suggestions?
Hi Guest and all
In first place I should say I own a Tanix TX9 Pro, so all the comments bellow should have this reality present.
I am assuming that Tanix TX9 Pro is equivalent to the Vorke Z6 Plus, because I used Magendanz roms (with changes explained bellow) to burn the firmware
into my box.
So this is what I did:
1) Using the amlogic Customization Tool and the "TX9pro-20171101" rom, I unpacked it, into it´s components (files)
I suppose I could have used the "VORKE-Z6PLUS-20171027-rooted-PC" as source, but this was not the case.
2) From this result I picked the following files and moved them to a temporary folder
DDR.USB
UBOOT.USB
bootloader.PARTITION
3) After closing the "Customization Tool" I removed the remaining files
4) I re-opened the "Customization Tool" and unpacked magendanz custom rom "Nexus_Z6_Nano_NHG47L-20171119"
5) Took the files from the temporary folder and replaced the ones from this extraction
6) Repacked the rom with another name as "Nexus_Z6_Nano_DDR3_NHG47L-20171119"
7) Re-flashed my box with this rom
... and it´s working
I should notice that when I tried to update this rom with the OTA "update_Nexus_Z6_Nano_NHG47L-20171119"
my box stop responding, I had to open it and made a connection between pins as explained in
so of course I don´t recommend that you do it
I kindly ask magendanz to comment my procedure and if there is a way to apply his OTA update without bricking the box :-)
regards
There are currently 2160 users online. 0 members and 2160 guests.
