regarding the resolution, I still have the issue without the OTA, you can try for yourself, so not good news
[ROM] Vorke Z6 / Tanix TX92 Stock & Nano Nexus ROM (Android 7.1)
Originally posted by Luca View PostI'm too inexperienced to try to reassemble the ROM as you did. Eventually if you send me a small guide I could also try. What you have posted is not clear to me at all . The previous rom, however, is already very good for me
By the way I am back to business, the pin trick did it's job, I am now trying something different, trying another rom, based on the Nexus GT1 from Magendanz
I think we should wait for a better opinion from Magendanz, perhaps he can explain some of this problems
Originally posted by Magendanz View PostSo, the bad Nano .img file isn't mine, right? This is something you created on your own for the Z6 Plus?
After correcting via settings, it turns right
Originally posted by Alianato View Post
It's pretty easy, just copy the OTA file (zip) into a card or USB PEN, then reboot into recovery and install it via TWRP, follow the menus, install, etc... selecting the unit where the OTA file is.
To reboot into recovery there are several tools in the google shop, the rom is rooted so there is no problem to do it.
I'm confused
Feb 11, 2018Installing official updates from your manufacturer or carrier is not supported by TWRP.
This is just confusing terminology. There's the OTA update format (https://source.android.com/devices/tech/ota/) that's defined by Android and comes as a .zip file, and that's definitely supported by TWRP and the local update feature in the Amlogic update app (Settings->About->System update in my ROMs). Of course, doing a local install of an OTA update (.zip file) isn't really over-the-air, since it's not being hosted on an OTA update service. TWRP doesn't support receiving these update files via an OTA update service, but it can install them from a local source.
Originally posted by Alianato View Postthis Tanix TX9 Pro box is terrible, I am just trying to get something usable
Even I had problems just brought home, modified the thermal part now works perfectly and never stops, never a reboot, freeze .temperature in idle 35 ° watching video fullHD reaches 40 °, with cpu stress max 54°.I think the problem is more in the DDR3 than the CPU
Originally posted by Jancales View Post
How did you fix the thermal part?
I removed the heatsink and placed copper plate on both the CPU and the DDR3, then I placed on a fan 4X4 and I took power from the USB port (which is activated only when turned on). Enlarged the holes on the side walls. For the fan I made a hole above the box. It is not noisy. I will put two photos tonight.
Originally posted by Luca View Postcan we create a new thread on custom rom for Vorke z6 Plus and Tanix Tx9 pro?
http://freaktab.com/forum/tv-player-...ms-android-7-1
There are currently 2875 users online. 0 members and 2875 guests.
