[ROM] Vorke Z6 / Tanix TX92 Stock & Nano Nexus ROM (Android 7.1)
Guest, I've used your ROM heavily for over a day now and it is very stable. I've had zero issues, and it seems to have fixed the random reboot issue I've been having on the stock Tanix firmware. It didn't happen often, but it was still annoying.
I love how your nano roms are very bare and only have the required things to run. I'm now using your nano nexus rom on 2 of my boxes.
Thanks for all of your work.
You can use this flashes also for TANIX TX9PRO, just replace ddr, uboot and bootloader with LP verison:
A) from TX9PRO TX9pro-20171222.img file > but LCD time numbers will be upside down rotated
B) from H96PRO PLUS CZ-S32-v5 board version for example aml_7.1_s912_q9377-S912_XGO_LP_mac-20171206.img file > without working LCD
C) from SCV4-Test1-Blue-PCB-H96ProPlus.img > LCD will be off = same as B)
or anyone suggest solution to working correct LCD due to TX9PRO board inside box is upside down than the TX92 board.
Other issue with newest 20171125 rom is described here: http://freaktab.com/forum/tv-player-...718#post703718Last edited by mXHX; 21 January 2018, 21:05.
if it helps to add it in future versions, someone adds BB2 PRO wifi drivers here https://yadi.sk/d/M5ODP3TS3PBMvu (it works with other boxes same as original img) but it's older version without .apk association so can't install apps from SD :[
Tanix TX9 Pro with Magendanz's rom + OTA, I suppose it will work the same for Vorke V6 Plus
Here are the files if someone wants to try them, of course I am not responsible for any damage it could bring to your boxes
by request I am posting updated links, see post nbrs #44,45 and previous for more explanations
cheersLast edited by Alianato; 31 January 2018, 01:23.
Originally posted by Alianato View PostTanix TX9 Pro with Magendanz's rom + OTA, I suppose it will work the same for Vorke V6 Plus
cheers
In a few days I will give a more complete judgment in terms of stability and more.
Thank you all for the work you are doing ..
There are currently 1599 users online. 2 members and 1597 guests.
