UPDATED - Minix Neo X7 - Finless 1.5a ROM
I tested this rom with kernel_20130822_160805_phja_t428_1080p_cpu1920h_dd r720_vsfsam. Link:https://www.dropbox.com/s/apt6ud17lw..._phja_t428.zip
With this kernel working wifi no ethernet.
Stock: Perfekt
Archos H/W: Almost perfekt if systembar is up, very choppy when systembar is down.
MX H/W: Very choppy
MX H/W+: Perfekt
MX S/W: Perfekt
Originally posted by benster1 View PostTesting with archos over cabled ethernet from ac ryan playon hd mini 2.
No choppyness perfect view!!!
Use ethernet not wifi. Choppyness is most of the times over wifi!!!
Perfect rom i tell ya!!
Verstuurd van mijn HTC One met TapatalkLive as if you were to die tomorrow. Learn as if you were to live forever
i am using installed the 1080p rom without airpin. i didnt have a shutdown till down, i didnt have with the 0.4a either. i have though a strange prob. when i installed the rom with the large fonts, there is no boot animation on reboot/Boot. the device boots up, and i think it gets into standby mode, because i have to press enter or eg down arrow for three times to activate the screen.
this happened also on the rom with the 160dpi, after changing the density with build.prob editor.
Power off button
OK what I mean by power off button is when I press the button in the status bar the pop up menu only gives me 3 choices. Sleep and reboot. The button in the middle is missing which was power off.
No one else is seeing that?
As for making Audio settings stick, this was a problem even on 3066 ROMs.
I never was able to figure out how to make it stick.
Re: NEW - Minix Neo X7 - Finless 1.5 ROM
Originally posted by Finless View PostOK what I mean by power off button is when I press the button in the status bar the pop up menu only gives me 3 choices. Sleep and reboot. The button in the middle is missing which was power off.
There are currently 2238 users online. 2 members and 2236 guests.
