UPDATED - Minix Neo X7 - Finless 1.5a ROM
Originally posted by baxxtor View PostTrhuster, how do you use the kernel with no wifi or no Ethernet? Is it possible to add wifi or Ethernet support to the kernel? That would be great. Thanks
Originally posted by Trhuster View PostI have no knowledge how to fix wifi/ethernet so i just tested video from usb memory. I asked if wasser could fix this for Minix X7 and he promised to try if he find any time.
Originally posted by Trhuster View PostDo anyone except me have random reboots from time to time? I have them 2-3 times every day when i watch on diffrent tv-apps.
Originally posted by baxxtor View PostIf Wasser was able to find time that would be awesome. His kernel works perfect for video! However, as I mentioned without Ethernet and wifi its close to unusable. I added the modules for USB Ethernet adapter to the wasser kernel and was able to get it working. I could browse the web and some apps would work. However, for whatever reason, most apps like even Google play store would not see or use the USB network adapter. They would give an error no network available even though the USB adapter was online, functional and had an IP address. It makes no sense.I wonder what the diffrence is in his kernel beacuse i find it best so far for mkv video.
Originally posted by Bigleg View PostBob suggested to me the opposite??
Not to beg but I could use a few donations for this work. Donations have been few and far between lately! I understand the economy! So if you like this ROM do your best to donate if you can. Thanks!
Hello Bob,
Remember you from all the Heli courses and instructions igot..
And no finding your brilliant work here also !!!
So i donated something to you today.
Your Work is THE BEST..
Enjoy,
Hey Bob,
i've installed your rom an my CX-921 (Exoon Power Pro) and tried to use your boot1080no_air_large.img.
Device didn't boot up, so i used my stock kernel because it was late and i don't want to test all your kernels ;-) Device bootet up well, IR remote works.
The reason i bought the Exoon Power Pro was that i had the hope, that this box can play all my Videos, no matter 720p or 1080p and passthrough the AC3 or DTS audio via HDMI to my receiver.
OK, HDMI is set to 1080p 60Hz, sound is set to RK Rockship. My device has only analog and HDMI output. The box is connected with lan. HDMI is connected to my Dolby and DTS Surround Receiver and then to my 52" Samsung LCD. I streamed some Files from my Synology Nas Drive.
1. All 720p Files, MKV, AVI or AVCHD TS-Files work perfect with both Stockplayer.
2. All 1080p Files, MKV, AVI or AVCHD TS-Files work quite good but not perfect.
MKV files played better.
3. I switched the sound output to HDMI Passthrough. Tried 720p Files with DTS und Dolby 5.1 sound. COOL! I got 6 discret channels over HDMI, no dropping frames. The only thing i've noticed, is that the CX-921 decoded the DTS and AC3 Audio files, not my receiver.
4. I played some 1080p files with DTS and AC3 5.1 audio. Output is set to HDMI Passthrough.
Audio still played well, but Video stuttered extremely! When i switched sound back to stereo, video is quite perfect again. So i suppose, decoding the 5.1 audio steals al lot of cpu power?
is there a way to let my receiver decode the audio files, that's what passthrough meant to be?
AnTuTu scored 18464, with 1080p 60Hz and status bar turned on.
Can you patch my attached Kernel to real 1080p and 1.8 GHz?
I tried other kernels, but than my Remote isn't working.
Here is my kernel:
CX-921_StockKernel.zipDonations are welcome and will be shared with other devs:
DONATIONS
CX-921 TV-Box without Bluetooth (RK3188 / RTL8188 Wifi), CX-921b TV-Box (RK3188T / AP6210 Wifi), T428 TV Stick (RK3188 / AP6330 Wifi), CX919 TV Stick (RK3188 / AP6210 Wifi)
There are currently 4465 users online. 3 members and 4462 guests.
