09T319362H989702A
UPDATED - Minix Neo X7 - Finless 1.5a ROM
Originally posted by pawnslinger View PostOka.... My X7 is a 2nd batch machine, so maybe that was firxed by factory after the 1st batch shipped....
ThanksLive as if you were to die tomorrow. Learn as if you were to live forever
no 1080 resolution in hdmi options in minix x7
sorry for asking probably obvious things but using 720p/1080i capable LCD TV i don't find 1080 options in hdmi settings.
I don't see there any resolution above 720p. My TV tells it's 720p as well.
Why i don't have 1080 resoluition in hdmi options? Is minix neo x7 flashed with finless 1.5a and latest official 20130822 1080fb rom not capable of 1080i
Your help is very appreciatedLast edited by Finless; 30 August 2013, 17:37.
Originally posted by jellywobbles View PostMay I ask how you identified your unit as a 2nd batch machine? (Mine is away for replacement)
While reading the "Minix Forum" this morning, I noticed that someone had tried the 1.4a Finless kernel with the 1.5a Finless rom! I don't know if that is kosher or not, but he said it was working good. That the video was much smoother and the audio passthrough was working.
If that is an okay thing to do... I guess I will upgrade to it. What do we call it... the half-n-half rom??
Anyway, I suspect that these ARM type systems aren't capable of generating interlaced video from a progressive source.
Hi Finless.
First off i dont know how theas thing work.
But would it be posible to base a custom rom on strauzo's rom?
Strauzo like A clean rom so a few things are missing but the rom seams rock steady and all x7 hardware is supported. So would this not be a nice base for a custom rom by you?
Appreciate your great work bob,that would be really cool to have .please consider.thanks
Originally posted by Casanoaa View PostDo you others have sound problem when you are on WiFi??? You hear the sound but it's noisy??
It's only when i am on ethernet.
Sv: UPDATED - Minix Neo X7 - Finless 1.5a ROM
Originally posted by a.b.c View PostWell, every now and then the sound gets a bit crackly with some louder ticking when using hdmi audio, not using headphone out. It seemed to get a little better with a different HDMI-cable. I never linked it to wifi since I'm only using ethernet. I thought I noticed a link with a lot of white on screen. Interesting to see if it is linked to wifi... I'm using 1.4a 1080p now.
There are currently 2234 users online. 2 members and 2232 guests.
