Thanks, I've been getting lots of shutdowns, will remove SD and test.
UPDATED - Minix Neo X7 - Finless 1.5a ROM
Originally posted by DomZ View PostHi Finless,
I've updated to 1.5a and AZERTY physical keybards are still in QUERTY.
You can try yourself.
Power Off button is back.
Thanks Finless
For guys that test SD card, it could be a good idea to give your SD card reference (model, ...), I will test also few a few sd card ...
Removed an hour ago, no shutdowns yet but not really been using it to be honest
Right, couple of hours in and no shutdowns, been doing all sorts, loading up and shutting down apps, messing around with mounted storage. Also after reading on here that someone had a bad SD slot and another thread on the Minix forum that a guy can't get his card slot to function correctly, I'm starting to think this was my problem the whole time.
Also system seems quicker or it just could be a placebo
There is code in Android that will remount the external SD if it discovers any file system errors.
You can see if it has done this by opening a terminal emulator (or ADB) and typing the command mount. It will then list all the mounted partitions. Check and see if the SD card is RO.
FAT32 sucks for this for sure!
Try this please. Format the SD card as NTFS in Windows and see if the crashing stops!
Yes NTFS SD card are supported since Android 4.1.1
Originally posted by Finless View PostThere is code in Android that will remount the external SD if it discovers any file system errors.
ive had a 4gb sd card in most the day, been playing some roms off it, never once had a crash today.
i had a couple of network issues (with my home setup) that ive ironed out today, since thats been sorted ive had no hang ups at all. (touch wood!)
seems like my problems was to do with the network?
this is like trying to find a needle in a haystack. Bob, there must be another way of debuging a box for crashes other than trying to pull the logcat??
edit, still no crashses, been on it all day so far!Last edited by danfozzy; 27 August 2013, 20:44.
Originally posted by Finless View PostUPDATE 8/26!
3) I added a 8GB and 10GB paramter file by request.
Enjoy,
I want to start playing some games, and I am a bit unsure how I should setup the rom.
Thanks for any help and clarification.
11) Added the DTS passthrough LIB's by request!
This was created by: stafstrom. Thanks for doing this stafstrom!!!
See here for more info: http://minixforums.com/threads/how-t...nd-spdif.2071/
The 2 files libmedia.so and librkffplayer.so have been replaced by this patch.
Should you have any trouble I left the old .so files as libmedia.old librkffplayer.old
If you want to go back just use ES File explorer
Turn on root explorer and mount system as RW.
rename the .so file to .xxx and rename the .old files to .so
reboot
The 1080p kernel is causing errrors in the XBMC video output (or the other way around). Video stutters even in MXplayer. I used the testfiles at http://www.auby.no/files/video_tests/
I switched back to 720p. I will stick to that for the time being.
Originally posted by handroid View PostThis is a great improvement! Love it. Too bad the special XMBC versions you need for this are giving issues with 1Channel and Common cache plugin.
do you guys think the minix neo x7 is the best android tv-box?
if not, wich one do you think it is?
And whats the best android stick (again, in your opinion)?
thanks (I'm interested in buying the x7)"Success is a lousy teacher. It seduces smart people into thinking they can't lose."
- Bill gates
OK formatted the SD in NTFS using Windows, reinserted it, did a full Titanium Backup using it as the storage medium. 1st pass only half the apps backed up? so ran it again and bamb! system froze, then had to pull plug. After and for the rest of the night I ran the box with no SD card inserted and it was fine all night and again this morning. So I'm really starting to think it's either my SD card or the reader that is the problem.
Am going to buy a new SD card later this week to see if that is the problem as mine is a real cheap Chinese, non branded one I got for free
I really hope that the SD is the cause of all my woes, TBH I can live without it if I have too and just backup to USB or my Network. Better than throwing money away on postage to China for a replacement with no guarantee of the box being any better as seems a few out of the very small number that have been sold are having freeezing/shutdown problems.
Admin at Minix implied it was my fault for rooting it!!! But did say if I send it to him direct he was change it for me but to be honest can't be bothered being without the box for a month waiting for the snail mail shipping as I live in Thailand.
There are currently 32684 users online. 1 members and 32683 guests.
