X99 TV BOX - RK3399 Mali - T860MP4 4/32GB ROM A7.1 HDR10 Dual WiFi BT4.1
    https://www.dropbox.com/s/4hb3aupn4zogldg/X99.rar?dl=0
    Hi all!
    Here is a link to the new update (R-TV BOX X99)_d32_ap6255_20180810_r1.img. - August
    Yesterday I updated firmware August, the problem with voice search remained.
    I will try today to throw off the new OTA update v1.0.2.
      Originally posted by bergamesk
      Hi 57beats
      with this latest ROM;did you check KODI(17.6 or 18.0) ?? how does it work
      i have no kodi in this rom and i have no lower ot higher info bar .
      but the rom is rooted
      Sent from my SM-J730G using Tapatalk
        Originally posted by 57beats View Post
        Hello.
        i installed the OTA rom upgrade.
        i check if its rooted with many root checkers apps all of them said ROOTED device.
        but i cant find the supersu.
        please if someone can give me the supersu apk compatible with 7.1.2.
        Best Regards,
        Hi ,
        that is not really needed , i think , did you tested it with an App that needs "root" ??? ,
        you can install "SuperSU" from Store , Google , Aptoide or similar , and test it , but
        maybe you can not update the Binarys , or it causes a Bootloop , then you must flash
        the Box once new , greetings / gefattern
          Originally posted by gefattern
          Hi ,
          the problem that the new upgrade removed two info bars up and down bar.
          everytime i need to close everything to open new thing.
          what should i do ?
            what should i do ?
            Hi ,
            you mean the Navigation & Notification Bars is this correct , for navigation , i use Pie Control ,
            like LMT.apk , similar Apps you can download from Store , for showing Notification Bar , i use
            ApexLauncher , u can set Icons to open up both , not sure if a mod of build.prob will help to fix
            this , good luck / gefattern
              Hi ,
              yes thats what i meant.
              thanks i will install them now.
              i have tried to instal supersu but it refuse to be installed.
                Hi ,
                Thanks a lot.
                i have fixed the navigation bar.
                but the notification bar not permanent always i should open the app.
                also supersu refuse to install in x99 from play store.
                  Thanks a lot.
                  Hi ,
                  nice to hear , but how did you do that , maybe other Users must know it too ,
                  so please explain what you did , thanks , with SuperSU it must be the same
                  Problem as before , but which ??? , dont know , this is a Problem for a Dev. ,
                  did you tested "root" with App that needs "root" , example , Titanium Backup ,
                  DroidWall ..... , or anything else ... ,
                    Hello! New firmware, there is no time for testing, sorry, but maybe someone needs to it.
                    t9_rk3399_d32_ap6255_x99_20181010_r1(隐藏kodi18.0).7 z · 705.92 МБ
                    https://www.dropbox.com/s/5fj8j3zf72...i18.0).7z?dl=0
                      Hi ,
                      not a big thing i did.
                      i go to play store.
                      i downloaded navigation bar app and then i go to accessibility and i turned on the navigation bar function.
                      about supersu i downloaded many old and new verions apk but none of them worked.
                        t9_rk3399_d32_ap6255_x99_20181010_r1(隐藏kodi18.0).7 z � 705.92 МБ
                        thanks
                          i still have two problems.
                          i need to activate the normal and permanent NOTIFICATION BAR and to install SUPERSU.
                          to be honest x99 is very very bad i dont recommend anyone to buy it.
                            "except picture quality"!!
                            X99 not recommended device ever!
                            Stock&ROMs bad
                            I only liked "Picture Quality" thats all
                              all i wish now is to install supersu
                              Stock&ROMs bad
                                Hi ,
                                why you not use the "rooted" Version from 22.5 , i think , i use it too ,
                                and SuperSU is installed , but you can not update the Binarys or App ,
                                not sure but i think the Yundoo Y8 Superceleron shall work , shall ask
                                Superceleron if it has the same Wifichip ,
