Is a recovery image that let us to make backups and restore of our actual firmware with all our applications installed, it makes a mirrored copy of our system. Very useful if you want to try install new roms and after test it you want to come back at the state you had before.
You can too install roms in cwm zip format (I will do a generic zip soon so you can install roms using this way) without use any external pc so simply, you copy the zip to the sdcard and flash it from cwm recovery.
This tool have more functionality like clear data,clear cache, mount and unmount file-system, format them, etc...
YOU DON'T NEED TO BE ROOT TO INSTALL CWM RECOVERY IN YOUR SYSTEM. So you can use it to make a backup of the stock rom or any rom installed in your stick.
From cwm we cant modify our partitions space, so we cant modify user app size or system size.
Where can i get this tool?
fun from androtab made the work, but I think that he is busy, no updates in his page for a long time.
You can use his generic cwm recovery and it is fully functional to make backup and restore them, except that if you have a problem with the kernel partition you will be not able to boot in recovery
So I used his generic cwm ram-disk and I modded it a little to add the stock recovery kernel on it. So with it you will be able to recover the stick if something was wrong.
All credits to fun_ from androtab, he did all the hard work, I only modded it, modify some little things, and add a kernel so we can format and flash the kernel partition from cwm. So it is not my work, it is fun_ work. If it works for you, then Thanks to fun_, if something fails or not work, for sure it is my fault.
How to install it?
A very good explication by MhagnumDw with other method to install it:
If you installed any Finless ROM, so I'll assume you know how to do get into flash mode and also know other things.
0) Open ROM Flash Tool.exe
1) Enter the flash mode
2) Extract the recovery.img from specific cwm image, rename it to recovery-cwm.img and place it in the folder FinlessROM (this step is only to facilitate the next step)
3) Let marked only the "recovery" and set the path FinlessROM\recovery-cwm.img (see image)
4) And last click Flash ROM
MhagnumDw
It is a explication for the rk3066 devices, but it will work for the rk3188 devices too.
A new way to install cwm recovery from any rom and without pc.(RECOMMENDED, specially if you use lewy roms)
1. Install from play store the free apps Terminal emulator (https://play.google.com/store/apps/details?id=jackpal.androidterm&hl=es)and busybox installer(https://play.google.com/store/apps/d....busybox&hl=es)
2. Open busybox installer, grant superuser permission,Use normal install (Not smart Install) then when it finish close the app.
3. Download http://www.freak-tab.de/leolas/cwm/term-install.zipfrom your stick, it must be downloaded in /sdcard/download/ (this is the default folder if you use the stock browser for download it.
4. Download your specific cwm zip from this thread and it need to be in /sdcard/download too.
5. Open Terminal emulator and write:
su cd /sdcard/Download unzip term-install.zip unzip theNameOfYourSpecificCwmRecovery.img.zip mv theNameOfYourSpecificCwmRecovery.img cwm-recovery.img sh cwm.sh
After write su you must grant superuser permission to terminal emulator.
I hope the instructions are enough clear but if you have any question I will be for here
Have fun.
How boot in recovery mode?
There is an apk made by Petrus (credits to him). This apk let us to reboot, boot in recovery or bootloader mode (NEED ROOT). Is the simplier way to enter in recovery, you can find it in:
http://www.freaktab.com/showthread.p...App&highlight=
You can use terminal emulator in your stick and write:
su reboot recovery
If you dont have a cwm for your specific device please upload your stock recovery.img and I will make one for you.
