cwm recovery for rk3188
    Originally posted by Molle View Post
    And particularly the 'RKAndroidTool' flashing method. I just tried terminal-based flashing and it worked like a charm.
    did you do it with lewy hibrid rom for T428 and it's working? please post a link how to use terminal based flashing.
      The terminal emulator instructions are in the first post.
      2 new recovery files added to 3º post for testing: k-r42 and doobol-u2 waiting for your feedback
      My devices:
      Gearbest.com)
        i tried again.....with the terminal window this time, it is not working. (T428) n is there a way to check if the cwm.img file has been loaded properly via terminal?
          check all the procces again and write here the result pls.
          My devices:
          Gearbest.com)
            the k-r42 don't work. i get a black screen when i try to get in to recovery
              Re: cwm recovery for rk3188
              What rom are you using?
              leolas
              My devices:
              Gearbest.com)
                What rom are you using? And what way of install?
                leolas
                leolas
                My devices:
                Gearbest.com)
                  leolas
                  I try it on new stock firmware, k-r42 hybrid firmware (hfw) v1.2.0, v2.0 and the one i upload for you for you. Here a link with the new stock firmware without root https://www.dropbox.com/s/73xa7kll0c...20130702_B.rar
                    Ok I will take a look on this one.
                    leolas
                    My devices:
                    Gearbest.com)
                      Doobol-u2-cwm-recovery.img is working OK !
                      Tested backup on and recovery from internal (nand) memory and external SD card (formatted by Android OS, don't know which format it is).
                      Don't work on external SD card formatted NTFS.
                      Thanks !
                        Thanks !
                        Good Thanks for the feedback, NTFS is not admited in all this recovery images, and I dont know how make it work actually but I will try to investigate it.
                        My devices:
                        Gearbest.com)
                          ...tried once more, same results. (T428). just to make sure it went ok, at the end in terminal, it ask to replace cwm.sh hit "Y" --> inflating: cwm.sh then -->inflating flash_image. thats it??
                            I do it step by step and I will post what you must write in red, the rest is what the terminal will show:
                            Code:
                            root@android:/ # [COLOR=#ff0000]su[/COLOR]
                            root@android:/ # [COLOR=#ff0000]cd /sdcard/Download[/COLOR]
                            root@android:/sdcard/Download # [COLOR=#ff0000]unzip term-install.zip [/COLOR]
                            Archive:  term-install.zip
                              inflating: cwm.sh
                              inflating: flash_image
                            root@android:/sdcard/Download #[COLOR=#ff0000]unzip T428-cwm-recovery.img.zip[/COLOR]                                               <
                            Archive:  T428-cwm-recovery.img.zip
                              inflating: T428-cwm-recovery.img
                            root@android:/sdcard/Download # [COLOR=#ff0000]mv T428-cwm-recovery.img cwm-recovery.img[/COLOR]
                            root@android:/sdcard/Download # [COLOR=#ff0000]sh cwm.sh[/COLOR]
                            [COLOR=#0000ff]wrote recovery partition[/COLOR]
                            root@android:/sdcard/Download # [COLOR=#00ff00]reboot recovery[/COLOR]
                            The last you must see is the blue line, this one informs that the recovery partition has been wroted, after that, you must write the last line (in green) and then the stick must enter in cwm recovery.
                            EDIT Please remember that linux is case sensitive. So T and t are not the same, write the lines exactly like they are in the red part.
                            My devices:
                            Gearbest.com)
                              Code:
                                inflating: cwm.sh
                              it worked ...!!! thank you. not with the reboot app though, only with terminal. one thing... is there a way to change resolution or make the fonts bigger in recovery? it is almost impossible to see the text.
                                Can you make a photo?
                                leolas
                                My devices:
                                Gearbest.com)
