cwm recovery for rk3188
Originally posted by leolas View PostThe user is currently not active, and in hiatus mode. please forgive me. will be back soon as i get my new rockchip device
I never used romdump to make a backup of Rom, so I can't tell you what is inside.
How to navigate in CWM with T-R42 or K-R42??
Hi, I'm new to the Android TV box and have a question about CWM, just purchased a T-R42, boot into stock recovery and how can I navigate up and down in the menue?? tried remote, mouse and none are working. The T-R42 or K-R42 only has one button on the box which is the power button, no vol buttons. Thanks
Re: cwm recovery for rk3188
Originally posted by buhohitr View PostHi, I'm new to the Android TV box and have a question about CWM, just purchased a T-R42, boot into stock recovery and how can I navigate up and down in the menue?? tried remote, mouse and none are working. The T-R42 or K-R42 only has one button on the box which is the power button, no vol buttons. Thanks
RE:
@buho
Do you have stock or CWM recovery? you said in the earlier post that you booted to the "STOCK RECOVERY"
@leolas
i've read that you are a kernel master, btw how does the kernel in rk3188 works, how can i uncompile/unpack/read the kernel.img,
and about partion sd card from CWM,
i tried it earlier, yesterday to be precise, and it work but ended up with 4gb instead of the usual 6gb, i've also increased the system.img offset to twice the amount of the original, then relocated the start parameter of the next image for it,
but now when i enter and re partition the sd it doesnt work, even to a smaller size, it just stays in there or hangs up, also i can check if the system partition really gets bigger, and why my internal SD hangs up on a re-partition.
About the partition, ive made the swap partition of the sdcard the highest amount when i first formatted it, since i thought it would increase performance but when i researched the net, found out that it will put a big risk to my nand for early retirement.. now i want to turn it off but cant repartition it...sad story...The user is currently not active, and in hiatus mode. please forgive me. will be back soon as i get my new rockchip device
Originally posted by buhohitr View Postthanks, but I'm asking about CWM, how can I navigate around? I need to know before I install it. Thanks again.
leolas.REMEMBER, YOUR FEEDBACK IS VERY IMPORTANT TO US.My devices:
@leolas
About decompile the kernel, you need to compile it using the sources, in Kernel development section there is a lot of sources uploaded to github.
Originally posted by leolas View PostWith an attached usb keyboard or mouse.
leolas.
Nice if I can help
CWM for MK802IV
leolas,
Could you customize an CWM image for MK802IV? The rom I used was http://www.freak-tab.de/neomode/MK80...3_20130809.zip from Neomode. Though it said to be compatible with UG007B, I tried your CWM for it (on OP) and only a black screen result. Thank you in advance! BC
There is 2 different mk802IV, one with 8188eu and the other one has AP6210. I don't know if they have more different parts.
RE:
leolas can you teach me how do you make cwm from img? what are teh files that you are merging, how do you identify the files and what are needed to be changed and retained.The user is currently not active, and in hiatus mode. please forgive me. will be back soon as i get my new rockchip device
Originally posted by th3f33 View Postleolas can you teach me how do you make cwm from img? what are teh files that you are merging, how do you identify the files and what are needed to be changed and retained.if there was a standard procedure for sure that I share it. But is like compile drivers for this sticks, rarely is 2 of them with the same process, each one of them are different, the good is that make cwm imgs can be made in 20 or 30 minutes, compile a driver can take 10-12 hours
There are currently 2175 users online. 1 members and 2174 guests.
