cwm recovery for rk3188
    Originally posted by leolas View Post
    Did you all the steps? Renaming too?
    Code:
    su
    cd /sdcard/Download
    unzip term-install.zip
    unzip theNameOfYourSpecificCwmRecovery.img.zip
    mv theNameOfYourSpecificCwmRecovery.img cwm-recovery.img
    sh cwm.sh
    Replace theNameOfYourSpecificCwmRecovery for your specific cwm zip name, for example in imito qx1 it will be qx1-cwm-recovery
    After write su you must grant superuser permission to terminal emulator.
    leolas.
    Yes, all items: 1,2,3,4,5 I did. Only I not replace theNameOfYourSpecificCwmRecovery for my specific cwm zip name, introduced as recovery.img you have written:
    root@android:/sdcard/Download# unzip term-install.zip - enter
    root@android:/sdcard/Download# unzip kr42-2-cwm-recovery.img.zip - enter
    root@android:/sdcard/Download# mv kr42-2-cwm-recovery.img - enter - In my opinion it does not matter, only have to type correctly.
    USAG: <source...> <destination>
    255|root@android:/sdcard/Download# sh cwm.sh - enter
    error opening cwm-recovery.img failed with error: -1
      Re: cwm recovery for rk3188
      USAG:
      mv kr42-2-cwm-recovery.img cwm-recovery.img -enter-
      Is neccesary write all. I am from my phone so maybe I made a mistake. Please read the steps one by one in first post.
      EDIT: Just arrived home, no I didnt make any mistake So please read carefully and follow step by step all. I try to explain clear, and I give you all the steps, if you miss 1 of them then the script will not work
      leolas.
      My devices:
      Gearbest.com)
        leolas.
        Not Understand. (Google Translator)
        Is neccesary write? mv kr42-2-cwm-recovery.img cwm-recovery.img
          Yes
          My devices:
          Gearbest.com)
            Yes
            So the second part (cwm-recovery.img) is not in the path of the file and the file is only the first part (kr42-2-cwm-recovery.img)????
            Of course, I'll try.
            Thank you.
              Thank you.
              The second part is the destination, so all devices share the same script. Try it and tell me.
              My devices:
              Gearbest.com)
                In fact, I expected it to be: no such file or directory.
                And so it happened.
                  I'll try to ask for a link to the Stock firmware at the seller, suddenly get.
                  The seller responded to my request to send the link to the Stock ROM for a device.
                  Jessica Wu: Hi friend,
                  If you want , pls send back , we can replace you with a new one.
                  Jessica
                  Maybe me should send?
                    Jessica
                    I will give you the precise instructions only for you.
                    Follow this guide, step by step, write the lines like they are (exact words):
                    You have terminal emulator and busybox installed.
                    With any file manager enter in /sdcard/Download/ and erase all files related to cwm installation. Erase all files there if you don't have anything important.
                    Download http://www.freak-tab.de/leolas/cwm/k...covery.img.zip
                    look at your /sdcard/Download folder with any file manager.
                    You must have this file:
                    Now enter in terminal emulator and write, (please exact words)
                    Code:
                    [B]su
                      cd /sdcard/Download
                    mount -o remount,rw /system
                    cp flash_image /system/bin/flash_image
                    chmod 775  /system/bin/flash_image
                    /system/bin/flash_image recovery kr42-2-cwm-recovery.img
                    reboot recovery[/B]
                    If this don't work for you, please sorry but I don't have more ideas. This are the most clear instruction I can give
                    My devices:
                    Gearbest.com)
                      Thank You.
                      If I do that on firmware Lewy20041 v.1.2.0. You do not have any objection? I had already put this firmware.
                      I have tried.
                      Firmware Lewy20041 v.1.2.0.
                      after entering the: chmod 775 /system/bin/flash image
                      Unable to chmod/system/bin/flash: No such file or directory
                      I'm sorry. Now I think, I typed flash_image no lower dash. Remade.
                      I remade it. But Recovery - Stock and with a red triangle.
                      Before, I just made ​​a mistake in entering commands.
                        Thank You.
                        I have tried.
                        Sorry, no more ideas.
                        leolas.
                        My devices:
                        Gearbest.com)
                          leolas.
                          Thank you very much, You very long worked with me. I have completely agreed on sending TV Box, to get a new one. Tomorrow I'll go to the post office and send. I hope, that with the new device will be possible to establish a connection you, in case of problems with it.
                            Guys, how to root my rk3188 (iMito QX1)? To use busybox need this change.
                              I am also wondering the same thing ... I just got my QX1 and those wierd flash tools never worked so hot on my other tv stcks in windows8... so I always relied on cwm
                              Perhaps add a link w/ instructions to OP ?
                                Oj, i will made a guide about this.
                                leolas.
                                My devices:
                                Gearbest.com)
