cwm recovery for rk3188
REMEMBER, YOUR FEEDBACK IS VERY IMPORTANT TO US.My devices:
Originally posted by leolas View PostYou can try, the worst is that you have to flash the stick againBut I dont have this device and I cant test this rom.
Ok i will try. But it is not my magioc is fun from androtab magic, I only port his work
thanks
Originally posted by dave3652 View Posthi, any luck with the rikomagic 802iv cwm?
thanks
Code:[SIZE=4]File Download:[/SIZE] Sorry, the file you requested is not available.
I flashed Finless 1.6b on my CX-919, everything seemed ok.
I then flashed the cwm recovery according to the instructions on this thread and when I boot to recovery - I just get a black, empty screen and the device is not recognized on the PC, so I have to unplug it and re-plug it to restart, and then the ROM loads normally, but no Recovery or CWM available - is there anything I can do to resolve this?
Thank you !
Re: cwm recovery for rk3188
Thank you !
Can you test if you can boot to recovery with the stock recovery? Thanks.
leolas.REMEMBER, YOUR FEEDBACK IS VERY IMPORTANT TO US.My devices:
Originally posted by leolas View PostYou are not the only one with this problem with this rom, and seems like if something is wrong in this rom wirh reboot to recovery. (misc.img??)
leolas.
I just hope I managed to backup stock well enough in case I'd need to return to it.
Thanks !
Originally posted by user941 View PostWith Stock ROM I had a recovery screen with some options, but when I tried to flash the recovery image offered here I got the same result (black screen and nothing more). I though maybe if I install Finless it would help, but seems it didn't.
Thanks !
Thanks for the info.
Originally posted by leolas View PostOk, if I understand well, in stock rom stock recovery works but this cwm recovery not. With finless Rom 1.6b cwm recovery dont work, but does it the normal recovery?
leolas.
Then I flashed Finless ROM - I didn't get a recovery screen. When I flashed CWM recovery - it still doesn't work - I just get a blank screen with no options.
Originally posted by user941 View PostIn stock ROM I can get to recovery (not CWM recovery) - when I tried flashing the CWM recovery, I got a blank screen.
link:
mk802IV-ap6210:http://www.freak-tab.de/leolas/cwm/m...covery.img.zipREMEMBER, YOUR FEEDBACK IS VERY IMPORTANT TO US.My devices:
[Qcan't =leolasthis one is ok, here is the link, please test it and report back if it works for your stick:
link:
mk802IV-ap6210:http://www.freak-tab.de/leolas/cwm/m...covery.img.zip[/QUOTE]
Hi, tried it and it wont install, don't tthink this is a problem with your zip though, think its my cwm, I get errors from it.
E / cant mount / can't find errors for all kinds of things. I used the generic rk3188 cwm ram disk install
Any other way to install this?
Originally posted by dave3652 View Post[Qcan't =leolasthis one is ok, here is the link, please test it and report back if it works for your stick:
link:
Any other way to install this?[/QUOTE]
Yes in first post of this thread there is 2 ways to install it. It is not a flashable zip from cwm so it cant be installed using the generic cwm
CS968 CWM recovery
@leolas
Please make CWM recovery.img for popular device CS968.
Link to recovery.img is http://ul.to/kt44jo6y
If you need full image, it is in first post in
Thanks!
Thanks!
There are currently 2099 users online. 0 members and 2099 guests.
