cwm recovery for rk3188
    Originally posted by lifeisfun View Post
    Happy New Year to all of you folks!
    Leolas, I know that you just returned but I have one more request.
    Just received atv580 box, and I like to try to install cwm on it. I have no links for the installed rom (Android 4.2.2 kernel 3.0.36+) is there any existing version I can try? Would need to use SD card method since there is no otg port and it did not come rooted unlike the atv520.
    For your mx1:http://www.freak-tab.de/leolas/cwm/m...covery.img.zip
    If your device is not rooted you cant make a backupof your full rom and without your stock recovery I cant make a cwm for it
    Can you connect from adb to it? What is your os? I can try to make a script to backup your actual rom and recovery from adb, and when we got a dump we can make a cwm for it.
    Originally posted by dv8ed View Post
    Lets say one day I need to return my device for manufacture warranty.
    If CWM is flashed on my device, if I use RockChip Batch Tool to flash original manufacture file "update.img" will that overwrite CWM and restore back to factory state?
    Device I'm referring to is TimingPower RK3188 if it makes a difference I also have a Minix Neo X7 don't remember what Minix provides as file to do write firmware.
    Yes, it will completely remove all on your nand, cwm inclusive.
    leolas
    My devices:
    Gearbest.com)
      Originally posted by leolas View Post
      For your mx1:http:/www.freak-tab.de/leolas/cwm/mx1-cwm-recovery.img.zip
      leolas
      Thanks Leolas, will test it on my mx1 when I get home.
      Regarding the atv580, it has two USB ports but no otg
      Would it be possible to adb over LAN or wifi?
      My OS is windows7
        Originally posted by hle5128 View Post
        can you make cwm for ippli mars i8 ?
        firmware is here
        (password: geekbuying.com)
        mars-i8: http://www.freak-tab.de/leolas/cwm/m...covery.img.zip
        leolas
        My devices:
        Gearbest.com)
          My OS is windows7
          Im
          Uff from recovery at least not
          from android maybe.
          Sure it has no OTG port? one of the usb ports are not OTG? I will take a look to this device.
          I just see his specification without usb OTG how you can upgrade it? It makes no sense Any instructions about update procedure in the manual?
          leolas
          My devices:
          Gearbest.com)
            from android maybe.
            leolas
            They are both full size USB ports
            took it a part and nothing hidden inside
            Steaming your favorite TV shows, movies or sporting events with MyGica excellent media players, 4k Android tv boxes, HD digital television receiver tuner stick
              from android maybe.
              leolas
              There is reset button on the bottom that on the atv520 was used if you want to use Linux XBMC installationinstead of Android. Android updates were done using upgrade app that was included on the device (This app is not included on the atv580 anymore ane the Android 4.2.2 install is very clean)
              The ATV580 looks exactly the same but now they use RK3188 chipset
              Here is the procedure how to:
              Firmware Installation Instructions (http://www.youtube.com/watch?v=8r07v...e&noredirect=1)
              1. Copy all files into a Micro SD card's root directory.
              *Note: Flashing with a USB Flash drive is not currently supported.
              Files should include:
              factory_update_param.aml
              factory_update_param.ubt
              spi_MX.bin
              recovery.img
              MX_LINUX-STVMX-update.zip
              2. Disconnect the power plug from the MyGica ATV520 and connect a HDMI cable with a ready HDTV.
              3. Insert the Micro SD card into the MyGica ATV520's Micro SD slot.
              4. Locate a paper clip and extend one end into a straight 2+ inch rod.
              5. Turn over the MyGica ATV520 and look at the bottom cover, you should see the MyGica logo north side and the text should be in its correct orientation.
              6. Locate a single pin hole with an "UPGRADE" word above it.
              7. Slowly insert the paper clip into the pin hole.
              8. When you feel a solid surface, the paper clip has reached the top of the service button.
              9. Gently push inward to activate the service button and remain holding the service button pressed.
              10. While the service button is pressed, connect the power plug and wait 10 seconds.
              11. Release the service button and remove the paper clip from the MyGica ATV520.
              12. A Android robot should appear on the HDTV. The MyGica ATV520 will now flash the firmware and reboot automatically.
              The system should now boot directly into XBMC. Remove the Micro SD card after a successful boot.
                Originally Posted by lifeisfun
                Never had problem to instaling cwm on my ImitoMX1 but since flashing 4.2.2 rikomagic rom on it the cwm refuses to install properly (Tried install it flashing the recovery partition). MX1 refused to boot after.
                This is the rom used http://www.freaktab.com/showthread.p...from-RIKOMAGIC
                And is used with this kernel? I want to say, do you use this Rom like it is? Is Mx1 100% compatible with rkm?
                Originally Posted by rubenvfreitas
                Hello there leolas.
                Look, do you think you can bring this to this specific device (bq Maxwell 2 Quadcore)? Its a rk3188 one and i tryed funs method without sucess.
                Leave you here the link for the files:
                https://s3.amazonaws.com/tabletfirmw...14-1546_HR.rar
                Thank you in advance.
                I will try.
                leolas.
                Hello there leolas,
                Regarding the post above, any news?
                  Re: cwm recovery for rk3188
                  Ju
                  spi_MX.bin
                  recovery.img
                  Wait, 520 is an amlogic device, so its nothing to do with a rk3188, they are so different, I will look at your link.
                  Hello there leolas.
                  I will try.
                  leolas.
                  Hello there leolas,
                  Give me a second, I think I did this recovery.
                  Here it is:
                  leolas.
                  My devices:
                  Gearbest.com)
                    Originally posted by wusel678 View Post
                    Hi leolas,
                    could you please make a CWM for MK 908 Finless ROM 1.7a?
                    You will find the whole ROM here:
                    www.freak-tab.de/finless/tronsmart_mk908_finless17a.zip
                    Thank you and best regards
                    Hello leolas,
                    any good news for me, too?
                      Originally posted by rceccleston View Post
                      Sorry, please find below a link to a full working ROM.
                      Sent from my M6 using Tapatalk 4
                      Hi Leolas,
                      Just wondered if a CWM recovery for the T-R42 V2 was still possible from the above link?
                      Thank you.
                      Sent from my Nexus 4 using Tapatalk
                        Ju
                        leolas.
                        Yes, the 520 is AMlogic chipset and the plan was that 580 will be new AMlogic chipset as well but then some how they decided to go with Rockchip. They look identical on the outside, use same remote...
                          Just to confirm, and thank you again, the MX1 CWM recovery works great now with the Rikomagic ROM
                          Used terminal to install it.
                          Great job!
                          THANK YOU
                            Hi Leolas,
                            Thank you.
                            Sure, let me some time, I hope to finish it this afternoon or tomorrow, I tried this morning but badoo download was so slow...
                            Rockchip without OTG is a very bad idea, if something goes wrong you will have tons of problems to fix it
                            Great job!
                            THANK YOU
                            Nice if it helps
                            leolas.
                            My devices:
                            Gearbest.com)
                              Ju
                              Here it is:
                              leolas.
                              Thank you very much. Confirmed working on BQ Maxwell 2 QuadCore leolas. Thanks again.
                                leolas.
                                I guess they will do it the same way as before, bootable uSD card and the reset button.
