cwm recovery for rk3188
    Originally posted by lifeisfun View Post
    Thanks Leolas, but link is dead?
    Can't wait to see what you'll discover
    Sorry my fault the link is:
    Originally posted by iran.android View Post
    my tablet device is rk2928sdk tsintech rockchip
    how can i install recovery for it?
    There are info, I didnt had any rk2928 device, so sorry I cant help.
    leolas
    My devices:
    Gearbest.com)
      پاسخ : cwm recovery for rk3188
      Originally posted by leolas View Post
      Ok I will try to do it today ;D
      leolas.
      My tablet device is rk2928 SDK tsintech rockchip
      Please give me cwm for my tablet
        Sorry but I dont know anything about that platform, I cant make a cwm for your device. As far I know in the web androtab.info there is information and a cwm for your device, I cant do more for you, sorry.
        leolas
        My devices:
        Gearbest.com)
          Great, thank you!
            my tablet device is rk2928sdk tsintech does it work for my tablet recovery?please give me my tablet recovery please assemble it too my custom rom and upload itthanks alot
              Re: cwm recovery for rk3188
              Please, can you read a couple of post up? Did you understand it?
              leolas.
              My devices:
              Gearbest.com)
                leolas.
                no
                unfortunately i didnt understand that explain
                please help me
                my tablet recovery cwm rom doesnt work
                i would like to install recovery for it
                Code:
                http://www.freaktab.com/showthread.php?10345-Root-tsintech-i30
                  HI leolas, ever have a chance to look at the firmware link i sent you for the MK902? NEO is about to make a rom for it, so a working custom recovery would just be the icing on the cake. thanks for all your work here.
                    I second that :-) Do you have a link to that thread?
                      I sure do. Been running it for about 2 days now with no hiccups. Running the overclocked kernel. http://www.freaktab.com/showthread.p...292#post147292
                        WLAN: RTL8188
                        LAN: RTL8201F
                        Bluetooth: Mediatek MT6622
                        MODEL: ekb311b
                        Back of Device / Board Print all specify the "Q7" or "XT-Q7-V10". I have dug into these forums trying to match any print from the board or model and have found nothing so far.
                        Heló i hace it device
                        It is ROM officie
                        He intentado descompilar la rom y cambiar el recovery por varios recoverys que encontre para rk3188 pero al compilar y volver a flasear la rom no arranca ' vuelvo a descompilar poner el recovery original, recompilo flaseo y funciona perfectamente.
                        Por si te sirve de ayuda todas las ROM de wasser de lewi para k-r42 o t-r42 no llegan a arrancar en cambio las ROM de minineox7 y la ROM de xbmc arrancan pero ni el bluetooth ni WiFi funcionan.
                        En estas rom al entrar en recovery no puedo hacer nada por que ni el mando que viene con el aparato ni el raton funcionan.
                        Serias tan amable de modificar mi recovery para poder instalar rom y poder hacer backup, muchas gracias
                        I tried to decompile the rom and change the recovery by several recoverys rk3188 but I found for compiling and back to flash the rom does not start 'I again put the original recovery decompile, recompile flaseo and works perfectly.
                        For what it helps all of lewi wasser ROM for k-t-r42 or r42 fail to start instead minineox7 ROMs ROM xbmc and tear but neither the bluetooth or WiFi work.
                        In these rom to enter recovery I can do nothing for you or the control that comes with the device or the mouse work.
                        Be so kind to change my recovery to install and to make backup rom, thank you very much
                          hola leolas
                          te subo mi recovery.img original
                          Es de una tv box android CS918B rk3188T AP6210 wifi ,bluetooth,lan,mando a distancia.
                          haber si le puedes meter el CWM recovery ese que yo no se como se hace.
                          Luego para que salga en pantalla como se hace ?
                          muchas gracias
                            Ok new recoverys for some devices:
                            cs918b: http://www.freak-tab.de/leolas/cwm/c...covery.img.zip
                            Q7: http://www.freak-tab.de/leolas/cwm/Q...covery.img.zip
                            cr11s-cs968: http://www.freak-tab.de/leolas/cwm/c...covery.img.zip
                            Please if you miss some cwm you asked before tell me, sorry but some weeks I am busy and most of the time I am from my phone, and only some days I got enought time to play with cwm recoverys.
                            leolas
                            My devices:
                            Gearbest.com)
                              Did you have time to look at the MK902? I have used CR11S-CS968 ROM successfully, so maybe CWM recovery for it may work.
                                muchas gracias Leolas, un abrazo
